Old August 26, 2013, 06:12 AM
IamSKW's Avatar
Default Current User in Regedit
Hello All,
Just a quick question. If i change a dword in regedit under current user will that take a affect for the next user that logs in?... so let say i change the dword on my account and my dad logs in will his dword now be the same?
Thanks
SKW
Old August 26, 2013, 06:45 AM
Nodscene's Avatar
No it won't. Any changes in Current User will only affect that user that is logged in.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old August 27, 2013, 04:45 AM
IamSKW's Avatar
thank you. Although i don't like your answer lol i figured that's how it worked
Old August 27, 2013, 06:00 PM
JD JD is offline
If both users are actively logged into the machine, you can look under HKEY_USERS and find the matching GUID for the user account (check the Volatile Environment key) and make the changes there.
Otherwise if the user is logged off, you can load the NTUSER.DAT file (which is the HKCU hive) in the user's profile folder. Just make sure you unload it afterwards!
Old August 27, 2013, 10:22 PM
if you want an easy way to get the users SID, just pop open powershell and copy/paste the following
Get-WmiObject -Class Win32_UserAccount -Namespace "root\cimv2" -Filter "LocalAccount='$True'"
just to add to what JD mentioned about loading the ntuser.dat for a logged off user. If you'd like to apply the setting to newly users, you can do the same to the ntuser.dat in the Default profile folder
Will my current pump be enough? esberelias Water Cooling 17 September 12, 2013 08:45 PM
Current Draw Reyzac Power Supplies 17 October 23, 2010 09:04 AM
Regedit fanspeed? BrainEater Video Cards 3 December 20, 2009 11:35 AM
Project with my current PC NoobLordSpud New Builds 10 November 24, 2008 06:19 AM
lol @ my current pc Kayen Case Mods, Worklog & Gallery 12 July 25, 2008 01:26 PM
