Old August 14, 2013, 10:09 PM
Default Different Blue Screens of Death
A couple weeks ago I constantly kept on getting a blue screen of death when gaming where the screen would appear for a second or two, then automatically restart itself. I solved the issue by modifying the System Agent Voltage in my BIOS to 1.107v which seemed to fix that issue.
Yesterday I was gaming and I got two different blue screens of death within an hour of each other. Both of these are unlike the ones I previously received. I am wondering what would cause these errors, and what the solution would be?
I have not installed any new software on my machine for almost a month now. My computer is not over heating as my room today is fairly chilled (GPU peaks at 75*C and CPU at 55*C). I have updated all my drivers.
Pictures of blue screens:
imgur: the simple image sharer
Windows/Minidump file:
http://www.filedropper.com/080313-11388-01_1
http://www.filedropper.com/080313-13057-01
i5-3750K (oc to 4GHz)
Hyper Evo 212+
16GB DDR3
7970
ASRock Extreme4
Corsair TX750
Seagate 2TB 7200
Intel 335 240GB
Old August 15, 2013, 08:05 AM
I'd recommend start by looking at this article, suggests a power issue potentially.
Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
might want to start by looking through the eventvwr for any errors logged under kernel power, if you see any, try to downclock your cpu a notch, 200mhz, maybe a little more should be a good start as you're specs say it's overclocked
considering the problem went away a couple weeks ago by bumping the voltage, sounds like this could definitely be power related, you might be trying to draw too much somewhere and something may not be handling it so well anymore
Old August 15, 2013, 01:44 PM
"Quote This..."
Run some memory tests.
Old August 20, 2013, 08:45 PM
rjbarker's Avatar
^^^ Yes, but obviously the OC isnt stable, go back to Stability Testing and tweaking OC is where I would start.
Firestrike Extreme: 21.452
MARK 11: 32.530
Multiple Different Blue Screens lightninstrikr Troubleshooting 6 September 6, 2012 05:04 PM
Blue Screens & Freezing Everywhere! TokeR Troubleshooting 8 June 30, 2011 01:51 PM
Constant Blue Screens NeilGames Troubleshooting 5 March 29, 2011 06:48 PM
Blue Screens encorp Troubleshooting 21 January 21, 2011 05:05 AM
Random Blue screens xilocient Troubleshooting 15 December 1, 2010 08:37 PM
