Old August 10, 2013, 12:12 PM
sakage.shinga's Avatar
Default A silly question about wallpaper sizes & ratios
Hi guys,
So here's a silly question. I'm downloading wallpapers from a great site called InterfaceLIFT at the moment, and it got me thinking about resolutions & ratios, and more importantly, which sizes I should download. Obviously I'm grabbing the ones that are at my LCD's native resolution (1920x1200), but I'm also trying to future-proof by download a collection of other sizes & ratios (e.g. 2560x1600). This is just in case that I upgrade in the future and get a monitor with higher resolution, or even different display ratio.
So my question is this, do I need to use the exact display resolution that is native to my monitor to get the best picture quality? Or can I use one that is of higher resolution (but same ratio, such as 16:10)? Basically, I'll just grab the highest available resolution wallpaper of within each ratio group (e.g. 16:10, 16:9, etc.). Or will using a wallpaper with higher resolution than my LCD's native resolution produce system slowdown due to scaling on the fly with each wallpaper?
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old August 10, 2013, 12:58 PM
supaflyx3's Avatar
Higher resolution, same aspect ratio is fine. It'll look exactly the same, also wallbase.cc is awesome for wallpapers as well.
Silly WC question ntydon Water Cooling 2 August 7, 2012 07:15 AM
silly question gingerbee Networking 3 January 27, 2012 05:16 PM
Might be a silly question but... xghostz Off Topic 8 June 17, 2010 07:41 PM
Question on Rad sizes jmacadam Water Cooling 4 July 29, 2009 06:11 PM
Silly Question Maplicito Overclocking, Tweaking and Benchmarking 3 July 19, 2009 11:49 PM
