Old July 6, 2013, 10:28 PM
r0k0's Avatar
Default Win32.exe using 100% load ?
ok so I ended the process but if it comes back, how do I prevent this from reoccurring ?
I was wondering why my PC went in 100% mode for a week now and finally figured it out cause I googled it lol
but all doesn't say how to prevent it from coming back.. if it does cause I think it will on my next reboot
any help ?
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old July 6, 2013, 11:15 PM
IRQ Conflict's Avatar
Go to the start menu, type msconfig, ht enter. Go through the non microsoft items in startup and disable them. Reboot and then one by one re-enable them, until, hopefully you find the culprit.
Old July 7, 2013, 09:29 AM
wirerogue's Avatar
sounds like a virus to me.
Old July 7, 2013, 11:17 AM
JD JD is offline
Yeah, "win32.exe" definitely isn't a part of Windows as one might suspect.
I would run a full scan in whatever antivirus you use along with something like Malwarebytes Anti-Malware.
How much could I load my corsair TX 750 V2 mardig88 Power Supplies 6 February 12, 2012 12:00 AM
Load question poroporo Power Supplies 6 January 23, 2012 04:16 AM
Load balancing Fudd Rucker Networking 13 March 7, 2011 04:13 PM
smp 8 = 13% CPU Load? zoob HardwareCanucks F@H Team 4 January 19, 2011 04:18 PM
Avast false positives? Win32:Delf-MZG (Trj) LionRed Off Topic 6 December 3, 2009 07:05 PM
