-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Ubuntu 12.04 opencl help! (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/60583-ubuntu-12-04-opencl-help.html)
Masteroderus April 7, 2013 09:14 PM
Hello!
I am having trouble getting opencl to install on ubuntu 12.04.
I want to install the sdk v2.5, but running the regular installer it doesn't unpack the opencl tar and for the life of me i can't get opencl to work for sdk v2.5
Any help is greatly appreciated!
EDIT: I'm running a 6950 or it would be as easy as sudo apt-get install python-pyopencl !
Masteroderus April 15, 2013 12:55 PM
I figured it out!!!!!!!!!!!!!!!!!!!!!!!!!!!
If anyone is mining with a 69xx series card make sure you:
-Download/install your fglrx drivers from the ubuntu software center
-reboot
-Activate the "experimental drivers"
-reboot
-download amd sdk 2.7, not 2.8, not 2.5 nor 2.4 nor 2.6, VERSION 2.7 ONLY
-Untar it, then (VERY IMPORTANT HERE) untar the two tar packages inside the main tar file. If you don't do this, the opencl won't install 100% of the time.
-Install sdk 2.7 from terminal
-Reboot
Then install all cgminer dependencies, sdl 5.0, and install/run cgminer as usual!
Jim April 15, 2013 01:24 PM
-reboot
-reboot
-Reboot
Nice job man!
Masteroderus April 15, 2013 04:12 PM
Thanks!!
If anyone needs help installing cgminer on 12.04 32 bit with ATI cards, send me a pm.
