Old April 2, 2013, 01:23 PM
Default XBMC
Antoher xbmc question.
I had xbmc running on my older quad core system and it was running perfectly.
I recently built a system using an i7 cpu. I moved the hdd with all of the media on to my new system and now when I start a movie it hangs for about 10 seconds as opposed to my older system which started instantly.
I am usuing the exact same version of xbmc.. (EDEN 11) I believe.. I'm at work right now so I can't verify that. The point is both PC's are running the same version and both are using win 7 pro.
The newer pc has way more ram and obviously better cpu.. any guess to what it might be?
If you need more specifics I will update later.
Old April 2, 2013, 05:01 PM
Shadowmeph's Avatar
eden 11 is fairly old isn't it? I think the newest updated version is frodo 12.1 maybe try and do what I did totally uninstalled xbmc and also deleted my profiles for the XBMC ( it asks you if you want to do this when you uninstall it) then re install the newer version.
Old April 2, 2013, 05:07 PM
I read a lot of people complaining about the latest release.. very bugy..
I intially intalled the latest one.. (FRODO) and when I tried closing the program it froze.
So I immediately installed the version I knew was less bugy.
How has it been running for you so far?
Old April 2, 2013, 06:18 PM
Very buggy here. Ill probably revert back to 12.0.
XBMC with two monitors biggyk HTPC Systems & Software 4 February 10, 2013 02:59 PM
BIG announcement for XBMC Arinoth HTPC Systems & Software 11 July 24, 2012 07:09 AM
XBMC 10 Released! Realityshift HTPC Systems & Software 14 January 20, 2011 04:16 PM
Does XBMC need windows 7? Blu O/S's, Drivers & General Software 1 December 14, 2010 01:41 PM
xbmc help scruff HTPC Systems & Software 3 December 12, 2010 01:51 PM
