Old March 26, 2013, 12:34 PM
Question CoreTemp
Hi everyone !
I play Starcraft 2 on my laptop (not a gaming one) and the game makes it run pretty hot ! (around 80C and my max temp is 85 !)
So i also run Coretemp just to monitor... and i was wondering if it has a impact on the game...
i mean, is Coretemp a "heavy load" program ? Should i keep it running while im playing ?
Thanks
Old March 26, 2013, 12:58 PM
Originally Posted by bostonkikiki View Post
Hi everyone !
Thanks
Coretemp is a minimal load program and for a laptop 80 is perfectly normal.
Old March 26, 2013, 01:09 PM
is it normal to be 5C below the Tjunction ????
Old March 26, 2013, 01:17 PM
Coretemp may not be reading properly. Try realtemp
Old March 26, 2013, 04:54 PM
The Quicken's Avatar
I like SpeedFan personally
Old March 27, 2013, 12:01 AM
I second the speed fan motion.
Old March 27, 2013, 08:19 AM
Ok.. but i'm pretty sure coretemp reads the temps correctly, since speedfan and aida64 tell me the same thing... My only problem with speedfan is that the program doesnt detect the fan ! I have everything up to date, so i really don't know where that problem comes from... It's a Samsung laptop 3 series with Win8. I took a look in the bios, but there's nothing there..
Old March 27, 2013, 08:25 AM
geokilla's Avatar
SC2 on a laptop... Not gonna perform as well as you will on a desktop. I've tried lol.
Laptops generally don't have good airflow and SC2 is both GPU and CPU intensive, causing the spike in temperatures. Especially when you got tons of army on the screen. My GTX 460 can barely handle muta-ling-baneling or Ultralisks, keeping the FPS above 30 at current settings.
Old March 30, 2013, 06:16 AM
Well i can't play on my desktop since it's a 10y.o. Dell pentium4 @2Ghz... and... half a gig of ram lol
Tags
coretemp
CoreTemp vs. Speedfan Jake_HT O/S's, Drivers & General Software 4 January 21, 2009 12:16 AM
Speedfan or CoreTemp ? Unklmo Overclocking, Tweaking and Benchmarking 4 April 12, 2008 12:53 PM
TAT vs Coretemp? Spblue Overclocking, Tweaking and Benchmarking 4 January 9, 2008 10:07 PM
