Old February 13, 2013, 10:17 PM
JD JD is offline
Honestly, I'm surprised people still "manually" defrag their drives... I never really notice any performance gains from it, and I've used PerfectDisk and Diskeeper in the past.
Old February 14, 2013, 08:19 AM
Nodscene's Avatar
I'd have to partially disagree with you JD. While a basic defrag doesn't seem to give much in the way of performance results, I have found that the boot file(s) defrag will make a computer boot faster. I haven't really used it on a Win7 or Win8 computer though so results may vary.
To the OP, defraggler is one of the best free ones out there so I'd say yes....it's worth downloading. Not sure you will see much in the way of real world performance results though unless your mechanical drive is nearly full and heavily fragmented.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old February 14, 2013, 09:38 AM
ok ! thank you guys for the feedback !
Old February 14, 2013, 03:31 PM
I use it but I also like the auslogics disk defrag program
Its free and works great as well its usually what i use!
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Old February 15, 2013, 03:03 AM
OC-Guru's Avatar
I'd highly recomend defraggler.. best free defrag tool out there.. Piriform ftw <3
Gaming rig: UNDER CONSTRUCTION!
Wife's rig / D3 Bot PC: 2x Xeon E5335 @ 2Ghz (8C/8T) | 24GB DDR2 RAM | ASUS GTS 450 1GB | HP OEM Socket 771 Motherboard | 4x Seagate ST9900805SS RAID0
D3 BT - Crispe#2349 (EU) - add me! :)
Old February 16, 2013, 06:16 AM
There's definitely a performance gain to be had from defragging for the OP because of that 5400RPM laptop hard drive. As Nodscene mentioned there will only be a noticeable difference if the a lot of the stuff on that hard drive is ignored by Windows defrag (e.g. hard drive very full, very large files, hibernation file fragmentation, etc.)
Tags
defrag , defraggler , program
Defraggler and Vista - Paging File rjbarker O/S's, Drivers & General Software 11 March 14, 2009 12:08 PM
