Linux Guru Script help I need some help understanding the approach I need for this task, What I want to accomplish is this: From Centos.6.3 run a script that will: 1) connect to windows share (mounted folder) 2) login with username and password 3) execute a script that will print the output of specific folders/drives on the windows PC to a desired location on my linux box. I've found various variations of connecting Windows to Linux, but nothing like what I want as listed above. Any help would be appreciated. #!/bin/bash echo "username" echo "password" ?? |
Some good ideas and info here -> https://bbs.archlinux.org/viewtopic.php?id=136199 |
Right now I'm running 2 scripts, 1 on windows to print output of HDD to a folder I have mounted as a share, and #2 I run a script on my linux box to copy that folder to the dir to be updated/overwritten. Works, but I really would prefer 1 script to rule them all...:doh: |
| All times are GMT -7. The time now is 02:05 PM. |
