-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Netsh in WinPE not working with Win8 (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/59047-netsh-winpe-not-working-win8.html)
ipaine January 9, 2013 03:00 PM
Ok so here is my issue and I hope someone can shed some light on it.
I have a WinPE disk that loads an Acronis front end for loading up my images. For the longest time now it has worked without issue. One of the commands that gets executed before the Acronis loads is a netsh int ip set address static command. This gives it the IP I need and then I can log into the drives that store my images. Now today I have run into an issue on two separate machines that have one thing in common, they both came shipped with windows 8. The error that now occurs when that netsh command is run is this, "The filename, directory name, or volume label syntax is incorrect" So needless to say I can get an IP onto it and can't get to my image files.
The first machine is a Asus CM6870 with a P8H77-M Pro motherboard in it, at least from what I can tell. And then the second machine is a brand new Samsung Series 3 model 350E7C-A03. Both give the same error. They also both were a bitch to get to boot from a USB as well. (Pro Tip, disable secure boot or look for option to boot from legecy options and not just UEFI).
I have been searching the webs for a bit today looking for an answer to this and so far have not found any reason why this would stop working on both of these boards. Anyone else out there have any ideas as to what could be going on with these new windows 8 ready boards?
JD January 10, 2013 05:58 AM
Are you using WinPE 4.0 (comes with Windows 8)?
How are you running NetSH? Is it part of the WinPE build or are you trying to run it from the local hard drive?
ipaine January 10, 2013 10:45 AM
Not WinPE 4, 3 (or maybe 2) I believe, the one that came with win 7. And yes the NetSH is part of the WinPE build as I can run it on other machines with blank drives.
