-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Which driver first ?? (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/58565-driver-first.html)
Dan December 15, 2012 03:29 PM
I will be installing a fresh W7 on a used SONY laptop I just bought for my niece. But Sony has tons of drivers (over 30) on their sites for this laptop.
My question is, is there a sequence for driver installation ??
I'm guessing, clear CMOS, install OS then drivers: Video card- Bios- Chipset and the rest shouldn't matter.
Is that right ??
KaptCrunch December 15, 2012 03:36 PM
look for service tag # it will get the corect drivers if systen still orginale built
Perineum December 15, 2012 04:12 PM
order shouldn't really matter. I typically start off with chipset first....
bigFOIG December 16, 2012 01:15 AM
Doesn't really make a difference. I personally try and get the video down first because I can't stand 800x600 or whatever resolution it lets you have. I download all the drivers at the same time and install them as they each finish.
Dan December 16, 2012 11:21 AM
Thanks guys,
Hopefully the tag# will give me less drivers to install.
Sony eSupport - VPCF132FD - Support
