-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Installing Win7 driver, 'side by side' error (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/58414-installing-win7-driver-side-side-error.html)
great_big_abyss December 8, 2012 10:49 AM
1 Attachment(s)
Trying to install AMD drivers on the following system:
F1A75-M Pro
A6-3670K
Win7 pro 64bit
See error message below. I installed Windows on Thursday and installed the rest of the drivers immediately after...chipset, USB, Audio, etc without any problems. I also installed Nvidia drivers, as I was trying (unsuccesfully) to get a GTX295 to play nice as the primary graphics card. I ended up removing the GTX295 and took a break, not touching the rig until today.
Today, I boot up the rig, uninstall the Nvidia drivers, then download 8.863.0.0 drivers from the ASUS website. The install fails, and I get the message shown below.
This isn't the first time I've received this message. This is the 3rd time I've installed Windows on this rig, and everytime I can install some drivers, and then I get to a certain point where the rest of the drivers refuse to install and uninstall because of this error message.
What is causing this, and what is the solution?
JD December 8, 2012 10:05 PM
Typically that means a Visual C++ Runtime is missing, but it could be other dependencies as well.
You could try running the Visual C++ Installer from this site: http://burf.cesidian.info/ as he's put together a fairly comprehensive collection of all the latest versions within that installer.
great_big_abyss December 8, 2012 11:01 PM
Thanks. I reinstalled Windows (again) and so far so good. I have all drivers installed, and quite a few games in there, too. If I run into the problem again, I'll be sure to check out that link. Thanks, JD.
