Old November 20, 2012, 12:11 PM
LoTech's Avatar
I had a similar problem a few months back and used this free tool from Norton/Symantec to remove it.
Norton Rescue Tools
Hope this helps such a pain to lose all your data.
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
Old November 20, 2012, 06:37 PM
genericllama's Avatar
Originally Posted by AkG View Post
try combo fix. if that doesnt nuke it....DL avira's rescue CD program. burn it run it, use it. if that doesnt kill it. Try Kaspersky's rescue CD. If those two dont do it...I'd probably sandbox the disk in another rig and use malwarebytes and SAS. If combofix, avira, kasp, malwarebytes AND Super AntiSpyware cant kill it....nuke the drive and restore from backup as you are screwed, blue and about to be tattooed. ;)
i follow a system like this myself. Always boot up safemode and check msconfig and just general running proccesses (and delete and turn off all system restore points). Then i run a scan of Malwarebytes followed by SAS (restarting in between), if its not dead run kasperky rescue cd and UBCD4WIN (havnt checked out avira's, just might), then resort to combofix last only because its a pretty heavy program. If my pc is still infected, I would likely nuke it (albiet i havnt come to that worst case just yet)
Congrats on the virus fix though. Consider running CCleaners reg cleaner and maybe Rougekiller to see if any part of the registry is severely affected.
So... i had a virus? bliz Off Topic 16 October 25, 2012 09:21 AM
Is it possible to get a virus across a network? NineLives O/S's, Drivers & General Software 12 May 2, 2011 05:22 PM
Do I have a virus? NineLives Troubleshooting 7 August 25, 2010 12:00 PM
conficker virus cmac79 Off Topic 21 March 31, 2009 02:59 PM
Virus problem...Help Kilauea O/S's, Drivers & General Software 21 August 22, 2008 08:21 AM
