-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   security program? (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/57904-security-program.html)
Overclocker~4.1 November 15, 2012 08:22 AM
security program?
i have a vidwo capture card designed for cameras. it came with software but it only works with xp and is hardware specific. is there any programs out there i can use that are designed for security purposes?
Squeetard November 15, 2012 08:57 AM
If you are running windows 7, why don't you run the software inside an xp virtual machine?
Windows Virtual PC: Home Page
Overclocker~4.1 November 15, 2012 12:47 PM
i tried that. the vm was unable to emulate the required vga output.the software requires an intel cpu and nvidia gpu.
LarkStarr November 15, 2012 03:03 PM
Why don't you try a REAL virtual machine? VMware or Virtualbox?
dandelioneater November 15, 2012 03:23 PM
Try virtual box.
Overclocker~4.1 November 16, 2012 10:29 AM
i would rather not ss thats just too complicated compared to just getting an updated program. i dont want to rin a vm for a simple security program.
LarkStarr November 16, 2012 10:51 PM
Your money to burn, brah! :D - Most capture software is (stupidly) hardware specific.
