Old October 29, 2012, 11:56 AM
AJR AJR is offline
Default Ext4 partition won't work on Linux?
Here's a weird one:
My win7 and Mint 13 OS installations are on an SSD and working perfectly. I partitioned my HDD to have an NTFS partition for windows, and an EXT4 partition for Linux. I think I made them all "primary" paritions, which maybe is the problem?
Anyway, the NTFS one is readable and writable from windows, but it doesn't show the EXT4 (which I figured.
The problem is that even though both the NTFS and the EXT4 partitions are readable from Linux Mint, I can't write to the EXT4 partition.
The only thing in that partition is a weird "lost and found" folder that I didn't put there.
Any ideas? Should I just reformat it as NTFS since mint seems okay with that? Or reformat in some other way?
Thanks!
Old October 29, 2012, 01:42 PM
Dude quit making separate topics my brain hurts.
Old October 29, 2012, 03:47 PM
NyteOwl's Avatar
EXT4 should be writeable. Check the permissions didn't get messed up. The system likely created the lost and found directory itself for garbage collection.
Obsolescence is just a lack of imagination.
Old November 2, 2012, 05:52 PM
AJR AJR is offline
Okay, I'll check that. Thanks.
Partition Help Niv Troubleshooting 9 September 19, 2010 02:03 PM
Fail to get work on linux CPU client? martin_metal_88 HardwareCanucks F@H Team 9 June 6, 2010 06:26 PM
SSD How to merge unallocated partition to primary partition in Windows 7 Mark Troubleshooting 22 May 14, 2010 04:32 PM
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks F@H Team 3 May 5, 2010 08:29 AM
Fat Partition to NTFS Boot Partition PaxeSalute O/S's, Drivers & General Software 1 May 2, 2008 01:28 PM
