-   O/S's, Drivers & General Software (https://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   CHKDSK and SSDs (https://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/57325-chkdsk-ssds.html)
Generic User #2 October 16, 2012 04:40 PM
CHKDSK and SSDs
system: MBP 13" 2010 running Windows 7 in BootCamp
SSD: Vertex 3
a couple of nights ago, while watching a youtube video, my system froze and started making BIOS beeps like mad. I hard-restarted and the system immediately jumped into CHKDSK run. After running the scan for a very scary 3 hours, the final report stated '0 bad sectors.'
...so....what does that actually mean? for an HDD, that would be an all-clear (after doing a backup), but for an SSD? does CHKDSK actually handle SSDs properly?
dandelioneater October 16, 2012 05:41 PM
I'm not sure if there is a black and white answer for this. If your system takes a dump and forces you to run it then ok, but usually you don't need too. AFAIK CHKDSK finds and fixes filesystem errors so it should find them on the ssd and I can't see it hurting it. I googled this a bit, but there wasn't really a definitive answer: CHKDSK on SSD? - AnandTech Forums
AkG October 16, 2012 07:33 PM
I've had it happen a time or two. Usually for whatever reason the 'dirty bit' get set in the MBR and chkdsk is set to run on reboot to make sure its not a big problem (and makes the rig reboot immediately in extreme cases). Last time it happened it was from an bad offset (just to show how long ago its been). Ran a fixmbr, presto strangeo SSD chugged along for ages (IIRC over 16mths) with no problems....before taking a dump (blown controller). Probably not related...BUT if it happens a second time....time to talk to the mfg'er.
Generic User #2 October 16, 2012 10:48 PM
um...is fixmbr a specific program?
Do you recommend I do anything at this point?
JD October 17, 2012 04:48 AM
fixmbr is only runnable during the Windows Recovery "setup" from the command line.
I wouldn't worry about it unless it becomes a common occurance. Could just be some incompatibility between Windows and Bootcamp.
rfglass October 17, 2012 10:44 AM
I had similar problem with ozc ssd , chkdsk wanted to run on every reboot, and always no issues if I let it run. I went into registry to disable it but the drive started causing me other headaches and tossed it for an Intel 520 120G drive. PC has been running smooth and fast ever since.
