-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   DirectX 10 or 11? (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/57272-directx-10-11-a.html)
Marute October 14, 2012 12:21 PM
DirectX 10 or 11?
So I downloaded the Nvidia 306.97 WHQL driver for my GT630M graphics card (Drivers | GeForce) but it seemed to lower my performance in Diablo 3 fps wise from 55.6 avg. to 43.5 avg. according to two 30 min. benchmarks from Fraps. So I re-downloaded and installed the 306.23 WHQL driver and it should be fine.
But according to Nvidia Control Panel my GPU supports DirectX11 yet when I check it appears that I have DirectX 10 installed. I don't know if I had DirectX 11 before I updated the driver, but should I download DirectX 11? What difference does it do having DirectX 10 or 11? Can updating the driver degrade the DirectX-version?
Windows 7 64 bit.
Thanks guys. :-)
Shadowmeph October 14, 2012 12:44 PM
I wouldn't really worry about that to much but if you must know go to the run command and type in DXdiag and it will tell you which version you are running but my guess is that since you are on win 7x64 and the GT630m I should be DX11
Marute October 14, 2012 12:55 PM
Using the DXdiag, it does indeed say DirectX 11 in the system menu. However in the screen menu it says DDI-version: 10.1. What does that mean? And if I go to the Windows Experience Index and press the "print details" button it also says DirectX 10 so I don't really know?
Marute October 14, 2012 01:00 PM
Don't know if you need or even want to see this. I thought I'd post it anyway. ;-)
System Information
Time of this report: 10/14/2012, 21:48:17
Machine name:
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: Danish (Regional Setting: Danish)
System Manufacturer: Packard Bell
System Model: EasyNote TS11HR
BIOS: InsydeH2O Version V1.15
Processor: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3948MB RAM
Page File: 1954MB used, 5939MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics Family
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_05111025&REV_09
Display Memory: 1760 MB
Dedicated Memory: 128 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO26EC
Native Mode: 1366 x 768(p) (60.014Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx 32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2418 (English)
Driver Version: 8.15.10.2418
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 6/10/2011 20:16:06, 8292352 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4266-11CF-E77A-1B25A9C2C535}
Vendor ID: 0x8086
Device ID: 0x0126
SubSys ID: 0x05111025
Revision ID: 0x0009
Driver Strong Name: oem12.inf:Intel.Mfg.NTamd64:iSNBM0:8.15.10.2418:pc i\ven_8086&dev_0126&subsys_05111025
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_10250511& REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6329 (English)
WHQL Logo'd: Yes
Date and Size: 3/15/2011 12:30:06, 2814952 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Razer Gaming Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0xBEEF, 0xFEEC
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB-rodhub
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ Razer DeathAdder 3.5G
| | | Vendor/Product ID: 0x1532, 0x0016
| | | Matching Device ID: usb\vid_1532&pid_0016&rev_0100
| | | Lower Filters: rzdaendpt
| | | Service: HidUsb
| | +-+ Razer DeathAdder 3.5G Keyboard
| | | | Matching Device ID: {16ea057e-3926-43c6-b752-353f3d0bf493}\hid_device
| | | | Upper Filters: mshidkmdf
| | | | Service: rzvkeyboard
| | | | | Matching Device ID: hid\vid_1532&pid_0016&mi_02
| | | | | Upper Filters: rzudd
| | | | | Service: kbdhid
| | | | Matching Device ID: hid\vid_1532&pid_0016&rev_0100
| | | | Service: mouhid
Gameport Devices
PS/2 Devices
+ Standard PS/2-tastatur
| Matching Device ID: *pnp0303
| Service: i8042prt
+ HID-tastaturenhed
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server-tastaturdriver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ ELAN PS/2 Port Smart-Pad
| Matching Device ID: *etd0500
| Upper Filters: ETD
| Service: i8042prt
+ HID-kompatibel mus
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server-musedriver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 341.0 GB
Total Space: 456.4 GB
File System: NTFS
Model: Hitachi HTS547550A9E384
Drive: D:
Model: PIONEER DVD-RW DVRTD11RS
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Danish), , 0 bytes
System Devices
Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_05111025&REV_04\3&115 83659&0&FB
Driver: n/a
Name: Atheros AR5B97 Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_002E&SUBSYS_660311AD&REV_01\4&3D1 316C&0&00E1
Driver: n/a
Name: High Definition Audio-controller
Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_05111025&REV_04\3&115 83659&0&D8
Driver: n/a
Name: Broadcom xD Picture Bus Driver
Device ID: PCI\VEN_14E4&DEV_16BF&SUBSYS_05041025&REV_10\4&BC6 2EF4&0&03E0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_05111025&REV_B4\3&115 83659&0&E1
Driver: n/a
Name: Broadcom Memory Stick
Device ID: PCI\VEN_14E4&DEV_16BE&SUBSYS_05041025&REV_10\4&BC6 2EF4&0&02E0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_05111025&REV_B4\3&115 83659&0&E0
Driver: n/a
Name: Broadcom SD Host Controller
Device ID: PCI\VEN_14E4&DEV_16BC&SUBSYS_05041025&REV_10\4&BC6 2EF4&0&01E0
Driver: n/a
Name: Intel(R) HM65 Express Chipset Family LPC Interface Controller - 1C49
Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_05111025&REV_04\3&115 83659&0&F8
Driver: n/a
Name: Intel(R) Mobile Express Chipset SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1C03&SUBSYS_05111025&REV_04\3&115 83659&0&FA
Driver: n/a
Name: Broadcom NetLink (TM) Gigabit Ethernet
Device ID: PCI\VEN_14E4&DEV_16B5&SUBSYS_05041025&REV_10\4&BC6 2EF4&0&00E0
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_05111025&REV_04\3&115 83659&0&B0
Driver: n/a
Name: Intel(R) HD Graphics Family
Device ID: PCI\VEN_8086&DEV_0126&SUBSYS_05111025&REV_09\3&115 83659&0&10
Driver: n/a
Name: NVIDIA GeForce GT 630M
Device ID: PCI\VEN_10DE&DEV_0DE9&SUBSYS_05121025&REV_A1\4&22F DAB3E&0&0008
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_05111025&REV_04\3&115 83659&0&D0
Driver: n/a
Name: 2nd Generation Intel(R) Core(TM) Processor Family DRAM Controller - 0104
Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_05111025&REV_09\3&115 83659&0&00
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_05111025&REV_04\3&115 83659&0&E8
Driver: n/a
Name: Xeon E3-1200/2nd Generation Intel(R) Core(TM) Processor Family PCI Express Root Port - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_05111025&REV_09\3&115 83659&0&08
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.051 3
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0 513
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.05 13
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.051 3
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.051 3
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
MainConcept MPEG Demultiplexer,0x00800100,1,2,mc_demux_mp2_ds.ax,8. 05.0000.27572
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.1771 3
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
MainConcept AAC Decoder,0x00800000,1,1,mc_dec_aac_ds.ax,8.05.0000. 24552
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.1751 4
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7 601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0 000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601. 17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.1 7713
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.1752 8
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.1752 8
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17 514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17 514
MainConcept MPEG Push Demultiplexer,0x00200000,1,2,mc_demuxpush_mp2_ds.a x,8.05.0000.24552
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.051 3
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.1751 4
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
MainConcept DV-Demultiplexer,0x00800001,1,2,mc_demux_dv_ds.ax,8.0 5.0000.24552
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
MainConcept AVC/H.264 Video Decoder,0x00800001,1,2,mc_dec_avc_ds.ax,8.05.0000. 24552
Track2Filter,0x00200000,0,0,Track2Filter.dll,9.00. 0000.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
MainConcept DV Dif Parser,0x00800001,1,1,mc_parser_dv_ds.ax,8.05.0000 .24552
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17 514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601 .17528
MainConcept (Broadcast) AVC/H.264 Video Decoder,0x00800002,1,2,mc_bc_dec_avc_ds.ax,8.05.00 00.24552
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
MainConcept VC-1 Decoder,0x00600000,2,1,mc_dec_vc1_ds.ax,8.05.0000. 24552
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.1 7514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.1751 4
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.760 1.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.1 7713
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Dump,0x00000000,0,0,,
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
MainConcept DVCPro HD Video Decoder,0x00600000,1,1,mc_dec_dv100_ds.ax,8.05.000 0.24552
MainConcept DVCPro 50 Video Decoder,0x00600000,1,1,mc_dec_dv50_ds.ax,8.05.0000 .24552
MainConcept Stream Parser,0x00400000,1,2,mc_demux_mp2_ds.ax,8.05.0000 .27572
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0 000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601 .17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Track1Filter,0x00200000,0,0,Track1Filter.dll,9.00. 0000.0000
MainConcept DV Video Decoder,0x00600000,1,1,mc_dec_dv_ds.ax,8.05.0000.2 4552
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.1751 4
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.177 13
Cinepak Codec efter Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.175 14
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17 528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17 528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17 528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
1.3M HD WebCam,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
dandelioneater October 14, 2012 01:45 PM
If you have a DX11 card and latest drivers then you are good to go i think. When you play a dx11 game for the first time i think that it checks to make sure that dx is up to date and will prompt u if it isn't. There aren;t that many dx11 titles anyways.
frontier204 October 14, 2012 08:15 PM
Originally Posted by Marute (Post 662303)
Display Devices
Your computer is using nVidia Optimus isn't it? The computer is reading out the DirectX capabilities of your Intel Graphics which doesn't support DirectX 11, while your discrete graphics does support DirectX 11. As long as the game you're playing switches to the nVidia GPU when you start up the game you should be able to run in DirectX 11 mode.
Marute November 10, 2012 11:00 AM
Yes, it is running nvidia Optimus. It normally runs on the Intel integrated gpu while games switch to the Nvidia dedicated GPU, so it should all be fine. Thankyou. :)
