-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Dual boot Xp Pro 32/64 on New Rig WIP (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/5665-dual-boot-xp-pro-32-64-new-rig-wip.html)
misterlarry April 19, 2008 09:49 AM
I've found lots of threads on dual booting XP Pro with a different OS, but none that specifically explained the process for a 32/64 bit dual boot. After screwing around for the better part of a day, the best solution that I could come up with was to use PQBoot for Windows (menu item in PartitionMagic 8.0) to allow me to switch between OS'es after booting to default OS (for now I've used 32 bit). This works alright, but it is not really a true dual boot config. I couldn't get BootMagic to work properly at all. I'm sure there are better ways to do it. Any suggestions? Thanks.
werty316 April 19, 2008 11:26 AM
First you need to either have two partitions on one HDD or two seperate HDDs.
Then install whichever OS you want as your primary first on one partition then install the other OS on another partition and BAM, you are done.
Instead of when Windows boot normally you'll get a boot menu where you can choose which OS you want to boot into and if non are chosen, since there is a boot menu timer like there usually is, it'll boot into the first OS that you installed.
misterlarry April 19, 2008 01:22 PM
I used PartitionMagic 8.0 for partitioning the first HDD. I set up two primary drives as C: (140 GB each) which would automatically make one active and hide the other one. I was just following the built in wizard, but as I said BootMagic wouldn't work at all.
I'm curious though, when you follow the method you just mentioned, is you're 2nd OS HDD also called C: or does it get assigned a different drive letter? I don't no if there is any advantage to changing my set up now though.
misterlarry April 23, 2008 06:41 PM
Dual Boot - No More
Well things were going OK for a couple of days until I wanted to show the system to a friend, and sure enough, I couldn't switch over to 64 bit. Well the New Rig - WIP is now officially on line and running only XP Pro 64.
belgolas April 23, 2008 08:05 PM
Just follow what werty said. I have dual booted XP32 and Vista64 with no problems. Even had mac osx once (but there were no drivers for my card :().
