So then you probably need to stop some of the software from loading at startup . the quickest way is either if you have ccleaner installed go into the startup inside there and turnoff which software you don't need to start up
or you could go to start\run and type in msconfig, when that panel loads go to start up and see what is on the list inside there and configure those so that they don't load at startup.
myself I am fairly lazy I just use ccleaner and turn of the programs that I don't want to load at star tup.
but the proper way would be to load which ever software ware and go into the settings and turn off the Load at windows start.
Folder : ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3 |
