Old August 14, 2012, 08:46 PM
Fudd Rucker's Avatar
I had the exact same prob with a vertex 2 60gb ssd. Would format and install windows without issue, but would experiance the exact same issues you are describing. Image your SSD and update the firmware on the SSD. Thats how I fixed my issue.
I couldnt think of something snarky or interesting to put here this time around.
GPU-Z Able To Disable GTX 580 Power Throttling mikellini Press Releases & Tech News 12 November 15, 2010 02:33 PM
Trying to disable speedstep mattydies CPU's and Motherboards 7 September 14, 2010 11:40 PM
How to disable CPU slowing down? biff CPU's and Motherboards 10 March 25, 2009 03:21 PM
how much ram do you need inable to disable pagegfile? Shadowmeph RAM 7 March 13, 2009 02:26 AM
How do I manually disable DirectDraw? mrlie3 O/S's, Drivers & General Software 4 June 4, 2008 07:40 PM
