Old August 6, 2012, 01:02 AM
Trial Member
Default Computer freeze issue
I have the following configuration on an assembled computer:
PHENOM II X4 + GIGABYTE GA 88 GMA UD 2H
Seagate HDD 500GB Sata
DDR-3 CORSAIR x2
HD 6850
BENQ 2220 HD
COOLER MASTER CABINET
COOLER MASTER SMPS 500W
Windows 7 64-bit
My computer freezes when I browse the internet and when using Chrome it freezes immediately. Firefox a little later and with Explorer I can manage to work with one tab. With more tabs the whole computer freezes. I have tried System Restore, Registry cleaner, defrag, anti virus scans Mbam scans etc but to no avail.
The problem started when I shifted the computer to a warmer room and stupidly put the chassis next to an inverter which emits heat. I used to face freezes but as a rare occurrence maybe 1-2 times a week - yes it used to be there before. I could open as many tabs as I wanted in chrome, firefox or explorer.
I have the problem is only with internet browsing - playing videos, music, work on excel, ppt etc is no problem.
I can't figure out whether it is a hard drive problem or something else. I remembered that I had changed the room earlier and the problem started so I have put it down.
Please help!
Old August 6, 2012, 09:32 AM
NyteOwl's Avatar
check that all the memory (and indeed all connections) are fully seated. Always a good idea after moving a machine. Also keep an eye on temps. lastly run memtest as browser-only freezing is usually a memory issue (sometimes hardware sometimes software).
Obsolescence is just a lack of imagination.
Old August 6, 2012, 12:13 PM
KaptCrunch's Avatar
mite be partition is corrupted
Freeze issue on new built pc. feubarkada Troubleshooting 70 October 28, 2011 04:33 PM
Computer to Component connection (HDTV) issue Arinoth Troubleshooting 2 March 22, 2010 05:20 AM
computer issue Haiden Troubleshooting 3 February 17, 2010 10:22 PM
Computer Freeze after running less than 3 Minutes. Pelt Troubleshooting 9 February 15, 2010 01:52 PM
Freeze Asspigeon Troubleshooting 32 July 26, 2007 06:41 AM
