Old July 24, 2012, 11:59 AM
Trial Member
Default PC won't boot properly?
On my PC I checked if my extra 1 TB HDD worked still (I thought it might have died) and after I plugged it in, I couldn't boot into the OS. I unplugged all my hard drives except my SSD and no matter what I try it launches start up repair and that doesn't do anything. I tell it to boot normally, goes to start up repair, I tell it to boot in safe mode, still goes to start up repair. I don't want to have to format my drive and reinstall all my programs and stuff again (I reinstall windows a lot). Anyone know what I can do? Thanks!
Old July 25, 2012, 06:01 AM
Ravenor's Avatar
All I can think of is go to the forums of your SSD manufacturer and see if anyone else has the same problem. They might have a fix for it. Heck it might even be a non-destructive firmware update if you are lucky.
Need help with with overclocking i7 860 properly. feerof Overclocking, Tweaking and Benchmarking 16 October 8, 2010 01:12 AM
Reboot and select proper boot device or insert boot media in selected boot device BrianHanna Troubleshooting 44 February 11, 2010 01:13 PM
My heatsink is not properly put on, can anyone help? phasetwo Troubleshooting 7 July 28, 2009 08:29 AM
My Boot settings (Bootsect.bak/Boot directory) installed to another HDD? chouchou Troubleshooting 7 December 21, 2008 07:46 PM
