View Poll Results: Do you turn on System Restore on C:/ SSD?
Turn ON 6 30.00%
Turn OFF 14 70.00%
Voters: 20. You may not vote on this poll
Old July 3, 2012, 05:03 PM
grinder's Avatar
I am a loyal acronis user, but do have redundant backup's ;). Acronis / System Restore / Windows NT Backup
Old July 3, 2012, 06:09 PM
I turn off system restore. I also disable virtual memory, hibernation, and recycle bin.
Old July 3, 2012, 06:48 PM
Virtual Memory is not recommended to turn off. The other turn go ahead.
Old July 3, 2012, 09:23 PM
It seems alot of you use Acronis, maybe I'll give it a try but the downside is I have to remember to back it up when installing new drivers and other stuff to c:
With System Restore I dont have to do anything, a much more convenient solution. I still have 65GB left in my c: which is a 120GB SSD so it's not likely fill up anytime soon.
Old July 4, 2012, 04:25 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Google "Acronis Non-Stop Backup". (Usually) No fuss. (Usually) No muss. It (usually) just protects everything not just your OS and does so (usually) without your knowing it. ;)
Old July 4, 2012, 12:40 PM
downloaded the trial version, let see what it does...
"Your CPU fan doesn't work properly. You must turn off your system right now and chec _dangtx_ HardwareCanucks F@H Team 17 December 17, 2015 10:01 AM
New SSD - How to restore using Win 7 Prolab Storage 3 November 29, 2011 12:48 AM
Restore Windows7 backup from SSD to HD bedouin Storage 1 May 10, 2010 03:28 PM
Windows 7 System Restore Messes Everything geokilla O/S's, Drivers & General Software 2 July 21, 2009 03:52 PM
System restore won't work at all, vista 32 donimo O/S's, Drivers & General Software 11 January 6, 2008 07:35 AM
