Old March 31, 2008, 10:26 AM
Thund3rball's Avatar
Originally Posted by SugarJ View Post
Make sure you use a defragger like JKDefrag that moves the files to the front of the disk, otherwise they may be scattered and limit the size of partition shrink.
Thanks to Thunderball for turning me onto that program, BTW.
You're welcome. Yes it certainly does an excellent job. I highly recommend it.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old April 1, 2008, 08:24 AM
SugarJ's Avatar
All that work figuring out how to split the partition, and Xubuntu will do it for you during install.
Installed Xubuntu 8.04 beta last night, very easy. Apparently 7.10 has problems with the 8800GT (too new) which is why I couldn't get that working.
So, boot CD, run install, move slider to size partition, press go, and bam! Multiboot system installed.
