Originally Posted by JD If this is server-class hardware, you could run VMware ESXi or MS Hyper-V. Both are lightweight hypervisors designed specifically for hosting numerous VMs. Far more efficient than using VirtualBox.
And either product should support auto-startup with delays in between to prevent resource contention. |
ESXi does let you configure which Virtual Machines will auto start on boot with set priorities. I don't know about the Citrix equivalent as I didn't test it much.
Originally Posted by lcdguy don't forget citrix zen server (or is it xen) |
It's Xen but I pronounce it the way you spelled it.
