Old March 29, 2012, 04:14 AM
taimoorali007's Avatar
Default An Risk by applying restrictions?
Hi guyz,
I just applied a restriction on my music and movies folders that "del" is marked on Deny rule. Now nothing can be delete but and be modified and copied. I wanna ask that in case on win corrupted or reinstalling win, will these folders and subfolders affect with this rule like is there any kind of data loss risk?
Plz tell me m worried bcuz i have no backup of those files just one copy on my HDD! PLZ!!
Old March 29, 2012, 04:25 AM
JD JD is offline
No, it won't make your files disappear.
After reinstalling though, you may have to forcefully take ownership of the folder and reconfigure all the permissions though. This is because the SID of your user accounts will be different as it's randomly generated each time you install Windows.
Old March 29, 2012, 07:53 AM
Applying 3M Di-Noc Carbon Fiber Film Mnpctech Guides & How-to's 48 February 7, 2013 03:07 PM
cheapest, low risk mobo for AM3+ cpu? Borg CPU's and Motherboards 1 September 17, 2011 09:12 AM
crash when applying overclocking settings **FIXED** BrianHanna Overclocking, Tweaking and Benchmarking 3 November 4, 2010 03:41 PM
Applying online. muse108dc Off Topic 7 November 11, 2009 09:41 AM
Re applying thermal compound to a GTX 295 GTX295Qsli Video Cards 0 March 16, 2009 08:17 AM
