Do you have a floppy? There are lots of bootable floppy options for cleaning a disk.
To erase the hard disk of a computer where Eraser cannot be installed onto:
You don't need to install Eraser onto the PC where you are going to erase.Take the following steps:
1. Connect to the Internet using your new PC and download and install Eraser.
2. Place a floppy (or CD) in the a: drive of your new PC.
3. Click on the Start button and then choose Programs->Eraser->Create Boot Nuke Disk.
4. Ensure 'Writing on Floppy' is ticked. Tick 'Formatting' if your floppy needs to be formatted.
5. Click OK. Result: Your Boot Nuke Disk has now been created.
6. Bring this Boot floppy to your old PC and place it in the a: drive. Now reboot the old PC. Result: All drives will now be erased (including the Operating System) IMPORTANT: USE WITH EXTREME CAUTION. |
Eraser - secure data erase tool to scrub files on your hard drive - FREE
