<~----> Ubuntu will not boot anymore - Hardware Canucks
Old March 19, 2012, 12:52 PM
Default Ubuntu will not boot anymore
My wife has an Acer One netbook which I installed Ubuntu onto for her as it came with Windows 7 starter. It was working fine for several months but now it will get to the Grub screen let you select the installed OS and then gives several errors while trying to load and go into initfsram. I have tried many commands in here but nothing works. I have also tried to edit the command line in Grub but still nothing. I have no optical drive but did the Ubuntu install from a USB key, so I thought, lets try and boot from USB. This does not work either and just gives a black screen with flashing white cursor. Please help.
Gamer with kids, therefore less gaming than before kids.
Old March 19, 2012, 04:58 PM
Keywork's Avatar
Can you elaborate on "nothing works" in command? I don't believe you have a GRUB issue. We may have a corrupt kernel or another critical part. If you're looking for some serious help, posting the errors which occur during boot up would be of serious help!!
Old March 21, 2012, 01:38 PM
Sorry for the lack of information, we have determined that the HDD is dead.
Asus p5k-e wifi don't boot anymore the_beast_gl Troubleshooting 4 March 25, 2010 05:20 AM
Reboot and select proper boot device or insert boot media in selected boot device BrianHanna Troubleshooting 44 February 11, 2010 01:13 PM
Tri-boot XP/Vista/Ubuntu Jon_di2 O/S's, Drivers & General Software 9 August 24, 2008 02:59 PM
Can't boot x64 anymore!!! francois methot O/S's, Drivers & General Software 2 August 20, 2007 05:06 PM
