Old March 23, 2008, 03:51 PM
Default Ubuntu - won't instal
Have a q6600 in a 680i mobo with 2g of Crucial Ballistic PC2- 6400 ram in an Antec 900 case, 2 500g Seagate SATA hdd's Vid card is GeForce 8800GT Alpha Dog Edition. It has an OCZ 750w psu. Currently the ram is locked to 1T and is at 4-4-4-12. Multiplier is 8, FSB is at 1828.552 mhz, CPU is at 3657.039 mhz, Memory 914.280 (DDR2) mhz. Its running Windows XP Pro SP3. Every time I try to instal Ubuntu v7.10 64 bit Desktop version it goes to the instal area , loads the kernel then just does nothing. Black screen. I want to make it a dual boot. One of the hdd is not assigned and I was hoping it would find it and instal there. Any ideas on where I've gone wrong ?
Old March 23, 2008, 04:00 PM
sswilson's Avatar
Try it at stock.
Could be you've got a slight instability (memory more than likely) that's not apparent under XP, or some high-mem issue that only rears its head during installation. (If I were to change just one setting, it'd be the 1t).
Old March 23, 2008, 04:02 PM
Thanks, will give that a go.
Old March 23, 2008, 05:18 PM
Linux can be A LOT more sensitive to a bad or instable system than Windows is.
