-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   @*&%@# Winpatrol (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/51975-winpatrol.html)
The Quicken February 27, 2012 12:56 AM
@*&%@# Winpatrol
2 Attachment(s)
I was required to install this program for for class to answer some Q&A...now I can't seem to remove it completely. Below are the steps I've gone though...I've combed the registry and hidden folders/files but it still shows up in my Startup..
Masteroderus February 27, 2012 07:46 AM
Have you tried using CCleaner? It usually gets rid of everything for me :thumb:
The Quicken February 27, 2012 10:38 AM
Yup, I'm an avid user of CCLeaner, no dice though.
Shadowmeph February 27, 2012 10:38 AM
if something is turned on it will show up in your task manager just make sure that it is killed if you see it then remove it , another thing is that there are a few programs out there that when uninstalled still leave the reg and also the folder on your system , so if you do remove the reg file the folder still exists . the best bet is to use whatMasteroderus suggested above, file ccleaner up use the uninstaller there to uninstall the program, then go to the startup part of ccleaner remove the program by unchecking it then delete it from start up after that is done click on registry tab in ccleaner and analyze , clean, then analyze it again and clean ( I repeat this until nothing shows up in analyze) then finally go to the cleaner part of ccleaner and repeat what was done , analyze, clean ,analize clean, this will get rin of every thing that was left by the program
SugarJ February 27, 2012 10:49 AM
Use codestuff starter to delete the startup entry.
CodeStuff :: Starter
The Quicken February 27, 2012 11:05 AM
Nice little program, but I've already done all this manually, the entry thats showing up in my startup is more like a ghost entry, I can see it but it has no substance. But obviously something remains.....
