Old February 22, 2012, 01:04 PM
Socrates_Johnston's Avatar
Default windows 7 strange problem after running CCleaner
Hey all.
Strange problem here.
Computer is running windows 7 home edition, and my little bro decided to run Spybot S&D and also CCleaner because he felt it was running slowly. After having run both programs and rebooting, all icons (spare a few ones here and there) have been replaced with blank white placeholder icons. Furthermore, in attempting to open a few different things I was given the following red X errors:
-'Computer' -- "the parameter is incorrect"
-'Control Panel' -- "This file does not have a program associated with it for performance of this action. Please install a program or create an association in the default programs control panel"
-'explorer.exe' -- "This file does not have a program associated with it for performance of this action. Please install a program or create an association in the default programs control panel"
Further to this, I was able to access the files of this computer via network from my laptop (to back up the files i needed).
Any ideas as to what went wrong? and better yet, how can I fix this atrocity? I suspect that CCleaner was not run correctly or interrupted before it could finish.
Old February 22, 2012, 01:51 PM
"Quote This..."
Or one of those programs could have found and cleaned a virus/malware. I've seen this before where a program replaces the shell command that runs exe's in windows from explorer.exe to their viral package. The antivirus cleans it out and you are left like this. Windows does not know what to do with .exe .msc files etc..
google how to restore explorer.exe as the windows shell.
Black belt in CAPS LOCK.
Old February 22, 2012, 02:35 PM
haha yeah it sounds like you had a virus in there that was re-routing all your .exes through it. Can't blame CCleaner for this one ;)
you need to install a registry fix from here - http://www.winhelponline.com/fileasso/exefix_vista.zip
Old February 22, 2012, 02:39 PM
Shadowmeph's Avatar
IS everything that was removed still in the trashcan because it seems to me like the icons were erased which would give you allot of problems.
or did he back up everything before he or she did everything?
if you have systekm restore you could always just restore it to sa previous date
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old February 22, 2012, 04:03 PM
system restore isn't an option until i apply the necessary registry fixes -- but I might as well do a clean install of windows anyways.
Old February 22, 2012, 04:19 PM
KaptCrunch's Avatar
before that, collect all updated OS hardware WHQL drivers and chipset for F6 option, burn to a disk/stik
check bios version also then install OS and have updates ready
once all installed and updates applyed. save a restore point and any time before any questional software so if messes up can go back
Old February 22, 2012, 07:05 PM
LMAO... who still uses Spybot S&D?!
Old February 22, 2012, 10:46 PM
The Quicken's Avatar
FYI, I've been using CCleaner for almost 2 years (I also put it on any PC I touch) and have never had a issue related to CCleaner.
Old February 23, 2012, 06:36 AM
recommend a better alternative?
Old February 23, 2012, 08:21 AM
Malwarebytes.
Strange Keyboard problem with keyboards Sneblot Peripherals 4 May 31, 2011 01:15 PM
Strange motherboard problem krajee Troubleshooting 2 July 30, 2010 02:48 PM
Strange problem Charmster Troubleshooting 7 July 3, 2010 06:13 AM
Strange power up problem jack2006 Troubleshooting 1 September 4, 2009 09:47 AM
uh...strange problem?.. omgwtf Troubleshooting 17 December 20, 2007 02:34 PM
