Old January 31, 2012, 10:44 AM
bvsbutthd101's Avatar
Default [SOLVED]Dumbest problem ever???
Basically when I go to rename my music folder in the start menu, it won't rename. I'm trying to rename it to Movies. I renamed it a while ago and it worked but a couple weeks later the folder renamed itself back to music. Now I can rename it to names I haven't used yet but a week or 2 later it just keeps renaming itself back to music.
Can't figure this out!!!!!
Here's a video of it happening. View in 1080p obviously
Can't Rename Music Folder - YouTube
Old January 31, 2012, 10:53 AM
Shadowmeph's Avatar
which OS are you using? Also is it the my music folder?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old January 31, 2012, 11:00 AM
G777's Avatar
Think you're going about it the wrong way, I'm at work on an Xp machine but I believe what you need to do is customize your start menu tab. Where you're trying to rename isn't the folder itself, it's a shortcut to whatever you share in music.
"Open Taskbar and Start Menu Properties by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
Click the Start Menu tab, and then click Customize.
In the Customize Start Menu dialog box, select the options in the list that you want, click OK, and then click OK again."
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old January 31, 2012, 11:17 AM
There's only a handful of thing in the list, am I able to pick a specific folder to put there?
Old January 31, 2012, 12:30 PM
I'm just the use the video folder and change the Library Location to my Movies folder on my HDD.
one of DICE's dumbest BF3 mistakes TedShackley Gaming 9 January 2, 2012 03:36 PM
Hard drive problem or Windows 7 Problem?! aeminence New Builds 4 October 13, 2011 06:46 AM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 06:01 AM
Dumbest Thing You've Read Lately Bean Counter Off Topic 19 November 22, 2010 03:56 PM
Dumbest things your dog has done... stoanee Off Topic 35 January 27, 2010 05:41 PM
