Old January 28, 2012, 07:40 PM
Silent_Avenger's Avatar
Default Hardware monitor for ubuntu 11.10?
So I'm setting up a smp rig for folding but I can't seem to be able to find a hardware monitor for ubuntu that works(I'm able to install) does anyone have any suggestions or possibly a link to a hardware monitor? All I really need is to monitor the cpu temp.
P.S. I'm an ubuntu noob as of now so a guide to installing the program would be helpful too.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old January 28, 2012, 07:55 PM
lmsensors
Old January 28, 2012, 11:09 PM
dandelioneater's Avatar
If you just want something simple there is something called xsensors that will give you cpu core temps. it is available in the software centre i think.
Old January 29, 2012, 06:54 AM
Here's the Ubuntu guide for lm-sensors: https://help.ubuntu.com/community/SensorInstallHowto
Xsensors and a bunch of GUI-based monitors are based on lm-sensors, which is what actually does the work.
If you can deal with using the terminal / console, then you can just type in "sensors" (you don't even have to sudo or be root) and get a dump of all your sensor readings.
I'll note however that some AMD processors need to override a driver before they'll give you a temperature reading: https://bbs.archlinux.org/viewtopic.php?id=120876
Ubuntu Help Rommel O/S's, Drivers & General Software 11 May 13, 2010 06:59 AM
CPUID Hardware Monitor - temps question somecanadianguy Overclocking, Tweaking and Benchmarking 8 June 16, 2009 05:11 PM
Ubuntu 8.04 miggs78 O/S's, Drivers & General Software 3 August 7, 2008 04:06 PM
Dell goes with Ubuntu Babrbarossa O/S's, Drivers & General Software 14 May 3, 2007 01:12 PM
