Old January 23, 2012, 01:54 AM
Default RDC over local Wifi vs remote wifi vs 3G
Just a quick question, is RDC ever really bottlenecked by the connection type? local wifi as in what you get in your house, 'remote wifi' would be what you get sitting in a coffee shop, and 3G being 3G in a windowed conference room.
Old January 23, 2012, 03:02 AM
supaflyx3's Avatar
Wifi? No. 3G, the ping would be a bottleneck.
Old January 23, 2012, 07:03 AM
JD JD is online now
Well any external network would be relying solely on your home connections upload bandwidth which I'm guessing is between 512Kbps to 1Mbps.
Remote Desktop was never designed for external access. I strongly recommend looking at VNC-based solutions instead.
Old January 23, 2012, 07:14 AM
Arinoth's Avatar
I'd recommend looking into Team Viewer as it is free to use if you are only using it on personal machines (IE not corporate), rather easy to use, and even comes with an android/iPhone app as well.
Wifi not working oneleg1 Troubleshooting 2 November 5, 2010 11:38 AM
XBMC wifi p3t3rson O/S's, Drivers & General Software 1 March 9, 2010 10:37 AM
little help with wifi gingerbee Networking 19 October 18, 2009 03:58 PM
Wifi Antenna magixx Networking 13 May 20, 2009 08:40 AM
