<~----> Program stopped working problem - Hardware Canucks
Old January 21, 2012, 05:32 PM
Default Program stopped working problem
Lately, I've been having a lot of my programs comming up with "program stopped working" error.
Is this s aproblem with the programms , Operating system or what ? I have the programmes and my OS on a
OCZ SSD.
Thanks.
ASUS P6X58D-E; INTEL i7 950 ; NOCTUA NH-U12P; PNYGeForce GTX 460 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 8 PRO 64-BIT.
Old January 21, 2012, 07:10 PM
Run chkdsk <http://windows.microsoft.com/en-CA/windows-vista/Check-your-hard-disk-for-errors> as a first step (same process for Vista and 7). You'll also want to check for malware, viruses, and anything that's hogging CPU or RAM.
Other than that, we'll need to know more about the errors (full description / screenshots). See if the error messages happen at after a certain action or if you get error messages that blame certain DLLs.
I know I had buggy printer drivers that crashed with that "stopped working" error every time the printer finished a print job.
Old January 22, 2012, 06:52 PM
Thanks for your comment. I have a very reliable anti spyware programme - Kaspersky Internet Security and all scanned are ok. I find the "Stopped working" error not localized to any type of program. My browsers ( IE9 and Chrome), Microsoft Office. Its just random. I also find that sometimes it will occur when I try to save or download a file. I have not been doing any printing. I also noticed that sometimes at boot or after I've left the system unattended for a while and the monitor wakes up from sleep, the boot drive is not recognized anymore. If I reboot, the boot drive order has changed. Other times it hangs at recognizing the boot drive.
I have replaced the drive (OCZ SSD) with another drive to eliminate a drive problem. I will run this for a day or two and report back.
Old January 24, 2012, 11:03 AM
Default Program stopped working - SOLVED
I have not had a repeat of the problem since yesterday - well, since replacing the drive. I am still not sure why the drive could cause this type of problem. Its an SSD - OCZ Vertex 3. Is there a way to check this drive and perhaps use it again ? Thanks.
Old January 24, 2012, 03:28 PM
LaughingCrow's Avatar
Somewhere along the way you might have got some corrupt program or data files from a crash, etc...
Old January 24, 2012, 08:35 PM
The drive has stopped working totally. Windows will not recognize the drive and have started the RMA process to have it returned to OCZ.
[Solved]ATI Display Driver has stopped working properly BFighter Video Cards 6 April 18, 2011 11:45 AM
Driver has stopped working and has recovered grifter11 Troubleshooting 8 January 16, 2011 11:18 AM
bluray program stopped working kyle_L Troubleshooting 1 September 24, 2010 04:04 AM
ASUS Xonar DX 7.1 stopped working any advice Shadowmeph Troubleshooting 1 July 16, 2009 05:51 PM
Mouse Stopped Working geokilla Peripherals 7 May 9, 2009 07:50 AM
