Old January 11, 2012, 10:04 PM
groundwire123's Avatar
Default using an existing key with different disk?
not sure how to word this, but I would like to reinstall windows on a laptop that was purchased from a store, and use the oem key for that system but not the original install disk. is this possible?
Does Microsoft store the key on the disk or what?
the one and only,
groundwire123
Old January 11, 2012, 10:35 PM
supaflyx3's Avatar
Just acquire an OEM copy that the key originates from, (IE home premium 64bit) keys arent tied to the disc, so as long as you're using the correct disc it'll work just fine.
Old January 12, 2012, 09:22 AM
Shadowmeph's Avatar
You could try it might just work and if it doesn't you still have I think one month to get a proper key.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old January 13, 2012, 08:35 AM
so if I have say a laptop (store bot) with a "windows 7 pro" oem key sticker on it, all I need is any "windows 7 pro" disk and it will work fine? And I'm not sure what Shadowmeph ment by still have 30 days to get a proper key. The key I would have must be proper cause it would be off a built system sold in stores. I just want to do a reinstall with the same key (to keep it legal cause that's the key that was registered to that computer) but don't have the original install disk. I think what supaflyx3 said is correct. At least it seems this is the case. thank you both for your feedback, but I'm not sure I have enough confidence yet to go ahead with the mission. Anyone?
the one and only,
groundwire123
Old January 13, 2012, 09:56 AM
The answer is yes. You'll need a windows 7 pro OEM disk to use with the key that comes on the laptop. The only problem you MIGHT have is depending on the type of laptop... sometimes the key is authed via the bios... in which case you'll need to do some advanced stuff I can't help you with.
If it works right away then great... if it installs and doesn't work then you'll need to look into the slic 2.1 bios.
Google this if you have problems: slic 2.1 bios
My stuff for sale.
Mah Rig
Old January 13, 2012, 05:13 PM
Thank you for the help clshades. What's this part about "The only problem you might have is depending on the type of laptop... sometimes the key is authed via the bios...." I have never heard of this can you explain or what should I be google'n to learn about this?
On another note, so If I have a pro key and any pro disk it should work? All the laptops you buy off the shelf are licensed and I should some how be able to reinstall the os with the key that is on them. This seems like the way to do it really.
the one and only,
groundwire123
Old January 13, 2012, 07:53 PM
Silent_Avenger's Avatar
Yea I don't understand what clshades is getting at either. I know a lot of times once the key has been registered it's then tied to the motherboard and sometimes you have to call into Microsoft or buy another key but that's only if you change the motherboard. So unless you changed the motherboard in your laptop I don't see a problem. But still don't know what clshades is talking about. :/
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old January 14, 2012, 07:11 AM
thats probably what he was refering to. Yah, is microsoft's way to make sure the key has only been used on one computer. If Microsoft detects new hardware, your screwed. So it sound like their should be no problems. To sum everything up: you can take a product key that has been activated/tied with one computer (motherboard) say "Windows 7 professional sp1", and then take any windows 7 install disk of the same distribution "Windows 7 professional sp1" and use it to reinstall windows using the key that has been activated/tied with the computer you are working with, not the key that comes with the os disk you are using.
in other words, your paying for a "genuine windows product key" not the installation disk. Right?
Thank you all who have helped. you have given me the confidence I have needed. Let me know if anything I said is not correct.
the one and only,
groundwire123
Old January 14, 2012, 07:31 AM
Actually you may not be completely screwed if you're swapping out a motherboard. I recently(like 2 months ago) had to replace my dead board and I only had an OEM version installed. I was able to install Win 7 Ultimate but it didn't accept my key and gave me instructions to phone in went through all the steps and my desktop has been working fine so far and getting regular updates. But yea if you don't have the disk and have to buy one you're already paying for a new key so you should be fine.
Old January 14, 2012, 11:06 AM
JD JD is offline
To clarify what clshades is saying, the keys provided with pre-built systems are special OEM keys. They require a unique form of activation and cannot be activated against MS's servers. It basically involves matching a certificate within Windows with a SLIC string embedded in the BIOS. If these 2 match, it activates, otherwise it doesn't work at all.
The $100-150 OEM licenses/DVDs you purchase from a retailer though, have a normal OEM key which does activate against MS's servers. It still usually is only good for 1 set of hardware. Any major upgrades requires you to phone MS and kindly ask for a new key which they typically provide.
And to answer your question, if the computer came with Windows 7, then it's using SLIC activation. If you use a standard off-the-shelf Windows 7 Professional disc, it may not activate. You might have to find the matching certificate for your laptop which is a fine line of legalities and we do not allow it on HWC. Hard to know for certain though unless you try! Regardless, you have up to 180 days (using slmgr -rearm) before you absolutely require a key.
Tags
laptop , microsoft , product key , reinstall , windows 7
"disk boot failure insert system disk" plutomok Troubleshooting 3 May 30, 2010 01:13 PM
Slow disk to disk to transfer rates. CroSsFiRe2009 Storage 3 December 8, 2009 08:01 PM
Transfer rates from Disk to disk and usb? Sagath Troubleshooting 7 August 10, 2009 01:50 PM
Disk 0 and Disk 1 in Disk Management MorePower Troubleshooting 10 August 9, 2009 03:11 PM
Disk Boot Failure - Insert system disk and press enter? lanken123 Troubleshooting 5 May 13, 2009 07:23 AM
