Old March 12, 2008, 07:31 PM
Default Where is the rest of my HDD
I am putting together my new rig tonight and installed Windows XP Pro.
For this installation I partitioned 50g of my Raptor 150g and installed the OS on the 50 Gig portion.
I expected to see my C Drive with 50gig and my D drive with 100g.
However, my D drive is my CD/DVD and my other 100g is missing in cyber world.
What did I do wrong and do I need to start over with a fresh install to get it back?
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 12, 2008, 07:36 PM
3.0charlie's Avatar
You need to format the 100Gb partition in order for Windows to see it.
Hydro-Quebec is salivating...
Old March 12, 2008, 07:38 PM
Do I do that with the Windows CD?
Old March 12, 2008, 07:40 PM
Also, should I install Mobo drivers and updates 1st or Windows Updates first?
Old March 12, 2008, 07:45 PM
3.0charlie's Avatar
No; right-click My computer, select Manage - then in the new window select Disk management. Then right-click the unformatted partition and select Format.
Old March 12, 2008, 07:48 PM
3.0charlie's Avatar
Board drivers are always first - then Windows Update. Otherwise Windows Update can't connect to the Internet, since the NIC drivers are installed by the board drivers using the board's CD/DVD.
Old March 12, 2008, 07:51 PM
Sweet thanks for the speedy reply, One last question,
I have read about making a sperate partition for a paging file to enhance performance. True? If so how much with 4 Gig of Ram on board?
Old March 12, 2008, 07:58 PM
belgolas's Avatar
you don't need a partition for paging. Especially with 4gigs of ram.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old March 12, 2008, 08:00 PM
Thanks all.
Old March 12, 2008, 08:04 PM
Man so many questions...
So I select NTFS obviously, should I stick with Default allocation size, should I enable file and folder compression?
