-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   simple virtu software question (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/46778-simple-virtu-software-question.html)
gingerbee September 27, 2011 02:54 PM
Does the fact that my z68 gene z motherboard supports virtue green software allow me to use an gpu setup f say an amd 6790 and my gtx 460 ????
thanks for any help i dont think it does but not sure
Desiato September 27, 2011 03:39 PM
I believe you're thinking of Lucid Hydra which allows for multi-GPU gaming with adapters from different manufacturers and families; a GTX 460 and 6790 can work together to render the same game, improving performance (in theory).
Lucid Virtu allows you to use specify tasks for each adapter; integrated graphics for media functions, GTX 460 for games, for example.
gingerbee September 27, 2011 07:37 PM
yes that was what i thought too i just need to hear some one else with the same take on it thanks
