Old September 14, 2011, 07:44 PM
Keywork's Avatar
Alright! I'm just about done. One quick question though! For the links. If there is more than one, you want them all in one field correct?
Shoot me a PM with your email so I can send it to you or I can copy and paste it here? Let me know!
Also, it's a perl script so you'll have to either install it on your windows box OR run it natively on any Linux distro.
Old September 14, 2011, 07:54 PM
SugarJ's Avatar
I'm pretty sure you can attach a zip to a PM, but I'm sure a few folks would like to see what you have done. Hint. Hint.
Old September 14, 2011, 08:40 PM
Keywork's Avatar
Code:
#! /usr/bin/perl -w
# KeyworK
# Script for DT dtscript.pl
use strict;
use warnings;
my $file = shift;
open (INPUT, "<$file");
## FORMAT
## Author,Content,Date,Retweets,Links,Link#
# Input
# epaulnet: Nanaimo Daily News: #Qaddafi backed efforts against al-#Qaeda: DND reports‎ http://t.co/iTVFkqh #Libya
# 04/23/2011 retweet
# Output
# epaulnet,Nanaimo Daily News: #Qaddafi backed efforts against al-#Qaeda: DND reports? http://t.co/iTVFkqh #Libya ,04/23/2011,0,http://t.co/iTVFkqh,1
my ($author, $content, $date, $retweets, @links, $length);
open (OUTPUT , ">output");
print OUTPUT "Author,Content,Date,Retweets,Links,Link# \n";
while (<INPUT>){
    chomp;
    if (/.*:.*/){ #Parses the main line
        #print "$_ \n";
        $_ =~ m/(.*?): (.*)/;
        ($author,$content) = ($1,$2);
        my @lines = split / /,$content;
        @links = grep (/http/,@lines);
        $length = scalar(@links);
    } elsif (/\d\d\/\d\d\/\d\d\d\d .*/){ #Parses the secondary line
        #print "$_ \n";
        my @line = split / /,$_;
        if ($line[1] eq "retweet"){ $line[1] = 0 }
        ($date, $retweets) = @line;
        print OUTPUT "$author,$content,$date,$retweets,@links,$length \n";
I need to go to bed, but I believe there is a bug if there exists a quotation mark in the content field, but I may be wrong. If you need any help running it, let me know!
Note: It takes the input file as an argument. ie: dtscript.pl input.txt
Old September 15, 2011, 04:37 AM
Arinoth's Avatar
Looks good, I'd of done it a slightly different way, but that may been due to the difference in programming language then actual algorithm
Here I am: here I remain
Old September 15, 2011, 05:40 AM
"Quote This..."
I'd run a search and replace to change any existing comma's to semi-colons first. Even if they did not cause a bug in your conversion routine, they will mess up the csv file.
Old September 15, 2011, 06:21 AM
Keywork's Avatar
Yup, I need to add a line in there to replace all commas and quotation marks with semi-colons or something. I'll try to make the adjustment quickly after i'm out of class. It's only one or two lines...
Note: I forgot to mention that last night when testing it quickly, I added some random quotes to the input file and ran the script. When I opened it in LibreOffice, it the CSV was broken, but when opened in Office, it was fine...
Old September 15, 2011, 08:45 AM
Dead Things's Avatar
Thanks Keywork, I played with it some this morning. It's perfect! Thanks so much - exactly what I needed. Simply amazing. I changed all the commas to semicolons and all the quotation marks to asterisks in the source document, and the csv file imported into SPSS perfectly. If I can return the favour in any way, please let me know. Don't suppose you'd be interested in a free 8800GTS?
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old September 15, 2011, 08:57 AM
Keywork's Avatar
Funny you mention an 8800GTS because the one I had in my secondary folding rig crapped out about a month ago haha. If it's working and it can fold, i've got a home for it! I would even cover shipping!
  #19 (permalink)
Old September 15, 2011, 09:19 AM
PM me your address and I'll ship it out early next week. Thanks again!
Need some expertise here =P feerof Water Cooling 6 April 7, 2010 08:17 AM
Building a Intel i7/X58 System.. need your expertise. exxoid New Builds 18 May 16, 2009 10:55 PM
Programming Phobia O/S's, Drivers & General Software 9 November 16, 2008 04:54 PM
programming how to's? klaiboi Guides & How-to's 7 June 22, 2008 07:23 PM
Need your expertise! More power? misterlarry Video Cards 10 April 3, 2008 08:25 PM
