-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   harddrive software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/46188-harddrive-software.html)
Mistertuxedopants September 3, 2011 07:42 PM
harddrive software
I just installed windows on a 60g (55 avail) and after it was done i had like 29 left. Is there software that can show me exactly where my space has gone:dots:
ilya September 3, 2011 07:58 PM
Pagefile, hibernate file, etc. Windows 7 uses quite a bit of hard drive space by itself, you won't be able to shrink your install much smaller than 10gb and it typically uses at least 16gb by default. Given your system specs 8gb was used for hibernate and 8/12 for the pagefile. Search for guides on installing Windows 7 on SSD's, OCZ forums has a good one IIRC.
Perineum September 3, 2011 09:50 PM
Use "treesize"
roh_ultima September 3, 2011 10:22 PM
yup windows eats up lots all on its own
i turn off hibernate and set my own pagefile size
8 gb is way too large
they made it so it would match the memory size you have...which seems silly, should be smaller the more memory you have
ultraman7k September 3, 2011 11:01 PM
I like spacemonger to determine what is eating up my space haha.
That being said I've always disabled hibernate, win restore and moved pagefile.sys to my other drive.
