Old August 14, 2011, 08:43 AM
Default Backup fully updated OS
I just brought home an ASUS G73SW-A1 and I'm wondering if I can make a backup of my fully updated Windows 7 Home OS. I made the recovery cd's and a repair disc. Is it possible to repair it to a fully updated OS instead of having to go through all the time of replacing all of the updates and programs after a problem has happened?
Old August 14, 2011, 09:09 AM
You'll need drive imaging software to do that since you're on Windows 7 Home. The Pro and Ultimate versions have drive image functionality built-in.
I use Acronis True Image which has worked but it is paid software. There are free alternatives but I can't recommend any as I haven't tried those recently.
Old August 14, 2011, 09:13 AM
Livestrong's Avatar
what is the drive software called that windows 7 has built into to pro?
Graphics/Media: 27" iMac | i3 550 | 1TB WD Black | 4GB DDR3 | HD5670 512MB
Gaming: 2500k /w H50 | P67A-G45 | HD6950 2GB | 60GB f60/ 1TB WD Black | 8GB DDR3 HyperX | SB Fatality | 850w Quattro | Cosmos S
Bluetooth Apple Keyboad | Magic Mouse | Touchpad
| Mac OSX 10.7
3x Dell U2311H | Logitech G15 & G9 | Sennhesier HD555 | Windows 7 Pro
Old August 14, 2011, 10:00 AM
lowfat's Avatar
Backup and Restore
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 14, 2011, 10:02 AM
ipaine's Avatar
I believe he would be referring to backup and restore. Although frankly I don't like it, but that said if all you want is one simple backup then it should work. I myself also use Acronis True Image and find it works quite well.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old August 14, 2011, 11:26 AM
Sagath's Avatar
I will 3rd Acronis. It is the best I have used out on the market and totally worth the $.
One of the really nice features Acronis has is the function for it to make a boot USB thumbdrive option. I keep an old 256meg one loaded with it at all times. Makes for easy data/OS recovery in a pinch. It is also user friendly and easy to use/understand even for non-technical people (my Dad has a copy, got a really bad virus, and restored his OS himself).
Old August 14, 2011, 11:47 AM
Shadowmeph's Avatar
what about EaseUS Free I was using that to back up my OS it is free and easy to use
Old August 14, 2011, 12:52 PM
lowfat's Avatar
I've never successfully had Windows 7's Backup and Restore work once. Everytime I've tried to restore and image it fails for one reason or another.
Queen of Dreams WIP
Big Lian Li
Complete
Old August 15, 2011, 06:11 AM
I'm with Ipaine and LowFat on the windows backup fail.
The Elder Geek has a section dedicated to slipstreaming updates into a copy of your OS install disk. Provided there is no hardware changes it works fine for a legit clean install. You will need a dvd burner to make the disk and your original install disk. RAID setups require some finesse and the boards raid drivers to be available too. If you are going to raid at all Acronis gets a 4th thumbs up.
Code:
[WTB] Socket 775 mobo that fully supports SSD chrisk Buy/Sell & Trade 1 June 14, 2011 02:22 AM
Fully Modular 400-500watt psu Blu Power Supplies 3 December 31, 2010 10:58 PM
[FS] C2D Quad PC fully loaded/water cooled CPU b1lk1 Buy/Sell & Trade 5 March 27, 2009 07:08 PM
Help! Card Not working fully? DavidDemise Video Cards 14 March 16, 2009 03:15 AM
FS: Ispiron 1501 fully loaded kcksteve Buy/Sell & Trade 0 April 29, 2008 05:57 PM
