Old August 1, 2011, 02:31 PM
Default Tis Out Of Control!!!!
so basically i get these temp directories growing by the minute,filling up me c partition very quickly.
in safe mode it doesnt happen, and in normal mode with all proggies turned off from device manager(read killed off) it still happens. no virus,spyware,etc was found as of 10 mins ago.
help or ill kill it lol!
danke
Old August 1, 2011, 02:55 PM
Nodscene's Avatar
What did you use to scan for viruses? Have you taken a look in your temp directory to see what files are filling it up?
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old August 1, 2011, 03:12 PM
avg,spybot.
so far ive narrowed it down to windows back up,which i set to disable from auto, in services.
Old August 1, 2011, 06:58 PM
Nodscene's Avatar
Post here if that ends up not being the solution and we can do some more looking.
I have to admit that I've pretty much lost all faith in Spybot and haven't used it in a long time. I've found that Malwarebytes is about the best at this point although Dr.Web CureIt is looking interesting. I just haven't had a chance to do much testing with it lately. I guess my point is to consider changing malware scanners. Obviously just a suggestion.
Old August 1, 2011, 08:45 PM
Andy's Avatar
I too have switched to Malwarebytes as primary. I still run both but MB tends to find everything Spybot finds and more.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
Old August 1, 2011, 08:51 PM
that did it. it was the windows backup tool,which im not sure why it was going when i had disabled it.
malware bytes? yes,good indeed i used it as well when i had issues a while back and it cleaned good
thing is, spybot AND with the running process there is very good,before you get anything
if you already caught the sida,i mean,bug,then mb is better,yes.
edit : it was backing up to another drive, but for some reason temporary folders were amassing by the truckload,literally, in the c:/users/username/roaming/folder ...
Old August 2, 2011, 06:57 AM
Nodscene's Avatar
Glad you got it sorted out.
If you are interested in trying new things you can replace AVG and Spybot with Microsoft Security Essentials. As much as I hate to say it MSE is probably my favourite free antivirus now. If you also like Spybot because it has the warnings (or used to last I used it) for system changes then you could use Winpatrol (BillP Studios - WinPatrol) which is a very lightweight program and free.
Old August 2, 2011, 07:08 AM
will give it a try on a fresh puter :)
danke
Old August 2, 2011, 07:40 AM
Nodscene's Avatar
My pleasure, let me know what you end up deciding.
In case you are wondering, I do tech support for law firms in Toronto so I deal with more than my fair share of viruses :) I just like to pass along what I've found works best for me, or at least what works best out of the software I've tried.
Old August 2, 2011, 10:04 AM
BobLoblaw's Avatar
I myself can also recommend MSE as pretty stalwart when it comes to protecting my compy.
Static Control Reyzac New Builds 15 June 5, 2011 03:13 PM
BP Is Out of Control kirk_d Off Topic 11 July 2, 2010 09:02 PM
I need a remote control TimTheEnchanter Peripherals 2 May 18, 2009 11:47 AM
FC2 control re mapping? upcoast604 Gaming 1 January 14, 2009 06:15 AM
Tis the season Digitaldemon Off Topic 0 November 30, 2007 06:23 PM
