Old February 9, 2008, 07:09 PM
Shadowmeph's Avatar
Default if you plan on running Linux don't use an ATI card
Well I give up on Linux well it isn't a Linux problem its an ATI problen there drivers are pretty bad for windows but Linux ati driver Suck huge I spent the paste week trying to config my Radeon x800 vid card and it failed every time well except once out of the 30+ reinstalls of Linux the drivers actually worked buit then I screwed up and never could get them working properly again I was going to install Linux on my new system I am building but since I am going ATI for the card ( because they are allot cheaper) I won't be installing Linux which is to bad I like Linux its just those fn drivers from ati so a little advice for anyone planing on running linux make sure you don't have a ATI card especially an x800 ( which are apparently the worst for Linux ) SO back to this winblows again oh yeah
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old February 9, 2008, 07:41 PM
+1 for nvidia
While their drives may not be the greatest to be executed for linux they do provide the support!
Old February 13, 2008, 04:18 AM
lcdguy's Avatar
i have never had trouble setting up an ati card on linux. Which distro did you try ?
Old February 13, 2008, 12:21 PM
Cheator's Avatar
You are permitted to use periods in this section of the forum :). It helps us read it better, lol.
Yeah I setup linux on my x800 and my x850 which worked ok, but I could never get 3d acceleration to work. Hopefully that will change now that they are releasing their drivers specs to the open source community.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old February 13, 2008, 02:24 PM
Mr. Cipher's Avatar
I tried ubuntu, fiery fawn or whatever it was called (the distro prior to the new one out now). Not reading up on the drivers before installing them, I tried to get my x1600xt's up and running. Of course, not understanding all the linux shell commands, I couldn't undo the driver installation and had to just scrap the whole linux install.
Booerns.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old February 13, 2008, 07:58 PM
lcdguy's Avatar
Booerns.
first off, did you follow the guide on installing the graphics drivers if not i would recommend it. Also if your using ubuntu there is a guide for getting it up and running much more decently. Finally when ever i have used linux with ati graphics cards they are generally more difficult than nvidia but not impossible. Also if you follow the guides you will end up with backup configs so if something does go south you can always restore to when it worked by overwriting the config file. I don't have direct links for the guides but if you search for something like Ubuntu Guide, there should be alink in there to the unofficial ubuntu graphics card wiki.
Old February 13, 2008, 10:49 PM
If your going to run Ubuntu I highly recommend you use Envy to install your video card drivers. It is an automated script with graphic and text interface that works for both Nvidia and ATI drivers. Just download the latest package from here Envy, install the package and run the script from the icon in the panel application menu, select either Nvidia or ATI, and your done! The script will download the latest drivers, compile them to the kernel, and configure your xorg.conf for you.
I also noticed that the Envy script allows you to use the nvidia-settings application when the drivers in the Ubuntu repository don't allow you to install it if your using their nvidia-glx-new package. One more thing, if your windows manager ever messed up and your install will no longer load up Gnome or KDE, you can use Envy from the command line by logging in and running Envy. Very good way to avoid having to reinstall Ubuntu because of a video card screw-up.
I'm not to sure about the problems of ATI drivers on other distros, I only installed an ATI card in Ubuntu.
Old February 14, 2008, 07:10 AM
Mr. Cipher's Avatar
Well, guide or no guide, x1600xt's are not supported by the drivers I used (which was my mistake), and I do not have the $$ to buy a new set of old GPUs that are supported for that computer (I do not want to run linux on my main machine).
I may try it again at a later date once I find some drivers that will support them. Until then...winblows xp it is!
i7 Red
C2Q Blue
Old March 17, 2008, 03:00 PM
AMD/ATI recently released the driver core for the linux drivers to the public. In the latest installment of Ubuntu; basic drivers are provided if you choose to install them. However, they are far from perfect, but they will mature with time. Still; as much as I hate to say it; stay with nVidia cards for now.
Old May 8, 2008, 01:46 PM
khelben1979's Avatar
I agree. nVidia has the best drivers and is easier to install, but..
A few years ago I managed to get real good performance with an ATi Radeon9800XT together with Linux! But... it didn't work right from the box. I needed to compile my own Linux kernel in order for the ATi drivers to work with full 3D acceleration. I was then able to play Unreal Tournament 2003 with pretty good speed!
I would recommend Debian over Ubuntu, any day. It's of course a matter of personal choice. I've been using Debian myself since 1999.
is it linux ati driver problem or the Card itself Shadowmeph O/S's, Drivers & General Software 2 March 15, 2008 07:10 PM
I'm getting that itch... EVGA step-up is running out zlojack Video Cards 9 February 7, 2008 09:01 AM
Running RAM 1:1 still the best? biff RAM 12 January 29, 2008 06:30 AM
Upgrade Plan Changes Jordan CPU's and Motherboards 3 July 28, 2007 03:55 PM
E6700 Running way too hot. r00tman CPU's and Motherboards 4 July 12, 2007 03:48 PM
