Old July 6, 2011, 05:23 PM
Default AMD 11.6 weird issue
I installed 11.6 drivers a few days ago. This morning I boot up my pc and get no display but a weird
coloredline on my screen. I tried another spare hard drive and windows installation was fine with display.
I'mrunning my primary display off an SSD and safe mode/last known good config did not work. So the
weirdthing is that I can only get display if I start hitting ctrl+alt+del really fast after windows logo. If I
don't dothat I just get this weird colored line on screen. When I do get into windows I had errors
reloading amd 11.6 drivers and got blue screen only once. I ended installing the previous drivers from
AMD and it still doesthe same thing. Has anyone had issues with 11.6 ? When I do boot into into
windows gaming does workfine. I think the only other error I had with 11.6 was that the drivers failed
installation or some crap like that. I did find ppl with problems with 11.6 but not the problem I'm having.
My lastest image backup done a few days ago was based on those drivers. I'd be mighty pissed if AMD
screwed my file system up with shitty drivers.
Old July 7, 2011, 09:46 AM
Did you disable your antivirus and firewall software? If you don't you will have some failed installation of drivers. Uninstall and redo.
I didn't disable mine on 11.4 and it caused some weird artifacts in games...so I just uninstall/reinstall with disabled antivirus/firewall and everything went fine.
1st - ASUS P8P67 Deluxe, i7-2600K o/c 4.6Ghz, Corsair Vengeance DDR3-1600 16Gig, 2x HIS Radeon 6970 CF, Custom WC from Dazmode, Corsair AX1200, Corsair P3-128 SSD, Coolermaster HAF-X
2nd - ASUS P5B Deluxe/WiFi-AP, Q6600 o/c 3.6Ghz, Corsair Dominator 6Gig, Sapphire 5870V2, Swiftech H20-220 Ultima XT, Corsair AX850, Antec 900
Old July 7, 2011, 10:22 AM
safe mode + uninstall + reinstall.
your files will be perfectly fine.
11.6 was smooth as butter for me.
Old July 7, 2011, 01:50 PM
Thanks for replies. I fixed issue with 11.6b hotfix.
weird 8800gt issue _dangtx_ HardwareCanucks F@H Team 8 March 14, 2010 06:07 PM
Weird system issue doup93 Power Supplies 12 November 20, 2009 07:00 AM
Weird Issue lcdguy Video Cards 12 July 20, 2009 08:52 AM
Weird Crash Issue ChuckleBrother Troubleshooting 8 May 25, 2009 06:37 PM
Weird Vista Issue lcdguy Troubleshooting 19 October 10, 2008 05:17 AM
