Old June 22, 2011, 07:29 PM
ipaine's Avatar
I have also used the slipstream method and while yes it can work (I had about 10 or so apps) but it takes way way longer than an image. You are still looking at a long install with the slipstream while with the image you can be much quicker. I have an image that I might be able to try on some different hardware tomorrow at work (maybe) and I'll let you know how it goes.
Really the image way is a much better option, even more so when you have larger software such as autocad and mastercam. Here is some info on the Acronis Universal Restore
"Nothing sucks more than that moment during an argument when you realize you're wrong."
https://www.evga.com/associates/defa...CUV5OY6FY0U02O
Old June 22, 2011, 10:47 PM
grinder's Avatar
i think you are asking too much out of windows XP
Windows 7 and Server 2008 (windows deployment services) will achieve what you are asking for.
Old June 23, 2011, 06:39 AM
chrisk's Avatar
Folding Captain
The Acronis solution might be the best bet.
I know my requiremnts are a pain and thanks all for the suggestions. 20 applications might even be underestimating the amount of crap that will be installed on the image now that I look at what we currently use (add Photoshop Elements, Macromedia Studio MX, some science probeware software, MS office, Open Office, as well as the CAD and Mastercam).
Fold for team #54196
Old August 10, 2011, 12:14 PM
Originally Posted by chrisk View Post
I thought about a slipstreamed OS disk which I have done before, but there would also be 20+ pieces of software that would also have to be reinstalled. I would like to have the software deployed with the backup media too.
This is being used in a high school environment, so the users are considered 'hostile' to the PC. Our current environment is too restrictive which causes issues with some software we want to use, so I am hoping to create a 'sand box' for these particular students to use that will not restrict them too much, but will allow me to quickly reimage machines when vandalism occurs.
Hello. First let me apologize to the mods for being a DW and having my first post be a shameless plug. i'm generally just a lurker.
chrisk, check out "Smart Deploy". It uses a similar deployment strategy to the "Golden Image" but adds deploy time driver injection/tasks and has a pretty simple interface. We may even have the driver packs if you're using enterprise class hardware. if not you can create them yourself.
The other guys are correct by saying it would be best to just create a clean master image instead of using a backup/recovery strategy. You don't have to use my software, there are quite a few ways to acomplish this using other products. However we do support WDS, CD sets and DVD sets as deployment media sources. I'm working on adding Linux PXE server support but that won't be ready for a month or so.
If not, feel free to pick my brain for an alternate solution.
Cheers
bg
Old August 28, 2011, 11:01 PM
ZZLEE's Avatar
AutoCAD 2012 - Online Tab - YouTube
Look Here
Auto cad on Andriod Phone / Iphone / Ipad / Andriod Pad
Targa 3 out soon
targa 2 = 1080P out by Hdmi
Yep Yep
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 29, 2011, 01:19 AM
ipaine's Avatar
And that has what to do with imaging software for dissimilar hardware?
Old August 29, 2011, 06:39 AM
chrisk's Avatar
Folding Captain
Nothing to do with my question, but I still sent the video to my colleagues as our license gives us the option to get 2012 in our labs. Cool stuff.
Dissimilar Metals, Galvanic Corrosion Corellon Water Cooling 13 July 8, 2011 05:02 PM
Disc Imaging Software timbruun Storage 5 July 23, 2010 09:35 PM
Best/easiest free imaging software? Delavan Storage 10 April 20, 2010 09:27 PM
Ghost/HD imaging software no_pulse O/S's, Drivers & General Software 27 December 3, 2009 07:32 PM
Disk imaging software. Il Duce Troubleshooting 6 December 21, 2008 10:27 PM
