-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Do I have worms? (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/43837-do-i-have-worms.html)
GeezerHT June 2, 2011 02:35 AM
Do I have worms?
Hello; I need help!
I have Windows 7 64 with Avast anti virus.
Here's a list of what started happening to my comp overnight a few days ago.
MS Outlook opens but doesn't respond.
Recycle bin does not respond.
MS Word doesn't respond.
The above might work after a period of time.
Start up takes longer, AIDA64 takes longer to load?
Malicious removal tool hangs if I'm even able to download it. It stopped on something like sysWOW64 dll.
Avast full system scan seems to hang aswell.
IE works.
Comp sometimes takes forever to shut down or seems to hang on shutting down screen.
There might be more symtoms but I've been short for time to see what's what!
I game well, I don't fix well:)
Do I have somekind of comp virus, worm, malware?
Please give me your thoughts.
Thanks
Perineum June 2, 2011 06:19 AM
I sound like a broken record here but rule out hardware first.
Easiest to check is RAM. Download memtest86 and give it a couple passes.
Bad RAM will do what you are describing.
stoanee June 2, 2011 06:34 AM
I gotta tell ya, a different image popped into mind at the first read of your thread title. Anyway, Peri is right, bad ram can give you what I call "unfathomable operation". Things are screwed right up and it can be difficult to troubleshoot without outright replacement of the ram. Also, I would try system restore to a known good date and run an av in safe mode.
Squeetard June 2, 2011 10:35 AM
I too pictured the op dragging his ass around on the carpet.
GeezerHT June 2, 2011 07:04 PM
Thx for your replies.
Ran the memtest four times....appox four hours and all passes with no errors.
Please advise what's next?
Should I take my COMP into Canada Computers for a fix?
Totally frustrated!
HELP
roh_ultima June 2, 2011 07:21 PM
might be spyware/malware
if you can't run memtest the other way to test RAM (your system memory)
is pull them all but one out. see how system works. if still flaky
shut down, take that one out and put in a different chip
if still iffy...try once more with different chip
if still iffy
you have a bug or something more than likely
Perineum June 2, 2011 07:24 PM
He said the RAM test came out fine. Good enough for me.
Download and install malwarebytes and see if it finds anything.
GeezerHT June 3, 2011 02:21 AM
I'm about to go to work..........
Waiting to see if my Outlook will respond(so far 15mins and no) so I can complete the purchase of Malwarebytes.
Thought I'd run a scan with Windows Defender and it's hung up after 48secs!
It's stopped at system32/drivers/usbport.sys if that means anything?
WAIT.......Outlook just free'd up aswell as my scan.
Scan(quik scan) is done and shows ok?.....wait, might give it another go.
To be continued, I need to depart for work:(
Do I get Malwarebytes or is it hardware?
Gellidius June 3, 2011 04:11 AM
as stoanee said, try anti-virus and anti-malware in safe mode.
Lanboy June 3, 2011 04:12 AM
Nuke & Pave .... I know it sound easy, once in a wild it's good to make a good cleaning
