Old May 28, 2011, 08:16 AM
Alpine's Avatar
Default Need advice for Linux Distro.
I have a old D3ll Dimension 3000 series.
Spec:
Pentium 4 + HT
DDR1 512mb
Ati chepo vid card.
I have try to install Ubuntu 11.04 and its very very laggy.
I dosen't know very well Linux distro and im asking which one i can dl and install on that old Dell b**tch that can run well ??
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old May 28, 2011, 08:37 AM
Pick one that you like:
DistroWatch.com: Put the fun back into computing. Use Linux, BSD.
My personal favourite is Puppy, but it requires a little more work to set up than other distros. You could also change Ubuntu to Lubuntu/Xubuntu, but that might be a bit complicated if you're not experienced with Linux.
Old May 28, 2011, 08:55 AM
I like Linux Mint these days its pretty good and does well for a pre-install Distro
Old May 28, 2011, 12:50 PM
Alpine's Avatar
Enaberif, thanks for the info. I will try it.
ilya: Thanks for the link !!
Main system
Server system
Old May 28, 2011, 01:36 PM
puppy for the slower machines, but mint/ubuntu in lower grade graphics should be ok even on odler hw...
Old May 29, 2011, 07:52 AM
Alpine's Avatar
iissshhhhhh graphic are also lagging with LinuxMint.....
Ill give a go with the Puppy one.
Thannks guys !
Main system
Server system
Old May 29, 2011, 07:54 AM
sswilson's Avatar
Aren't the ATI linux drivers still well behind the Nvidia ones?
Old May 29, 2011, 08:24 AM
Thannks guys !
Its not "Linux" that is laggy its the X Window you are using. I suggest installing Debian and running XFCE its the most lightest Window Manager around next to something like Blackblox
You bet!
Old May 31, 2011, 01:44 PM
Spec:
Pentium 4 + HT
DDR1 512mb
Ati chepo vid card.
Ubuntu is a POS now. Bad idea to install it on an older computer especially with all of Ubuntu's *changes*.
Just install Debian with XFCE desktop and you are set. Any issues or problems, you can google either Debian or Ubuntu 'solutions' / workarounds as there are still some similarities in usage.
ATI is supposedly catching up with drivers but it depends what you want to do with the graphics/video/card.
Alpine would have to use the ATI open source radeon driver anyway.
Old May 31, 2011, 07:48 PM
Actually for the very old (DX9 or lower) ATI cards, the open source "radeon" driver is pretty good for 2D acceleration. I had an ATI Radeon 200M IGP back then and it was fine for the Fedora / Ubuntu of its day.
Bootable AVG CD using Linux Distro sswilson O/S's, Drivers & General Software 6 April 2, 2010 06:51 PM
What Linux distro is for me? biff O/S's, Drivers & General Software 22 October 30, 2008 08:20 PM
anyone recomend a Linux distro for HTPC? Shadowmeph HTPC Systems & Software 5 June 17, 2008 10:05 AM
Good distro for HTPC use? durdy O/S's, Drivers & General Software 1 February 26, 2008 09:59 PM
Poll: Your favourite Linux Distro qwerty O/S's, Drivers & General Software 16 February 25, 2008 12:06 PM
