Old October 9, 2011, 01:32 PM
thread Resurrection
I just installe Ubuntu 11.04 over win7, created a 17GB directory, but that is ok, but it has all the outputs for the sound less the digital spdif out that I use. Had to activate Nvidia driver in order scale the resoution and I can't change the resolution either, it keeps it at 1920x1080, I would like to lower it. How do I do that? and where is the Apply button in Ubuntu?
Old October 9, 2011, 10:21 PM
m1dget's Avatar
Originally Posted by MARSTG View Post
thread Resurrection
iirc#1 -> with gnome go on the 'top' bar, go in the preference menu and click on either 'screen' or 'display' (i don't remember which) OR go edit manually in xorg.conf (not sure you want to actually do that)
iirc#2 -> there's no apply button in gnome
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
Bootable AVG CD using Linux Distro sswilson O/S's, Drivers & General Software 6 April 2, 2010 06:51 PM
What Linux distro is for me? biff O/S's, Drivers & General Software 22 October 30, 2008 08:20 PM
anyone recomend a Linux distro for HTPC? Shadowmeph HTPC Systems & Software 5 June 17, 2008 10:05 AM
Good distro for HTPC use? durdy O/S's, Drivers & General Software 1 February 26, 2008 08:59 PM
Poll: Your favourite Linux Distro qwerty O/S's, Drivers & General Software 16 February 25, 2008 11:06 AM
