Old May 19, 2011, 04:39 PM
Default Window refreshing problem.
Hi, I am trying to fix a friends computer (running windows 7) and just can't find a solution to his problem. The problem is that open windows keep refreshing at a seemingly random interval. This is causing text cursors and pop up menus (WiFi selection menu for example) to disappear without warning. I have thoroughly scanned the computer for viruses. I have checked the registry entry that controls window refreshing. (I forget what it is called) I have tried using system restore and reinstalling the video card drivers. Nothing seems to have any effect on the problem though. The only remaining idea I have would be to try using a windows repair disk. Any ideas would be appreciated.
Old May 19, 2011, 05:48 PM
ZZLEE's Avatar
Can you give us specs on the problem computer ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 19, 2011, 06:50 PM
It is an hp g61 with an amd athlon ii 2.1 ghz, 4gb of ram, and a mobility radeon 4200
Old May 22, 2011, 06:07 PM
I ended up reinstalling windows to fix the problem.
Old May 26, 2011, 08:39 AM
Considering that you already reinstalled I'm assuming the problem would have been fixed, but I'll just throw in as a piece of late tech advice in case it happens again, it might have had something to do with his keyboard drivers assuming that he has a fancy gaming keyboard that requires a separate driver install. Some of the proprietary software can be pretty buggy and unreliable.
Window movie maker windows 7 artifacts problem Remoth O/S's, Drivers & General Software 3 December 20, 2010 12:34 AM
How to install a window? Overclocker~4.1 Guides & How-to's 29 October 13, 2009 03:56 PM
refreshing H.W.C hightest Suggestions & Feedback 6 August 30, 2009 01:28 AM
HElp about window XP v0maru Troubleshooting 2 February 14, 2009 07:38 AM
Window Appliqués BALISTX Cases 5 October 15, 2007 08:21 PM
