Old May 8, 2011, 05:03 AM
KRAFTIG's Avatar
Exclamation HELP - Installing Win 7 64 bit latest updates...
I've tried to install the latest updates as recommended by the operating system, but it keeps failing. Would anyone know why? I've tired to installed one update at a time and it still provides an error message. I've attached a few images for you all. TIA!
Old May 8, 2011, 05:38 AM
Look in your add/remove programs in your control panel. If you see "Microsoft .NET framework 4 extended" and the other is "Microsoft .NET framework 4 profile view", uninstall them and then run your windows update again from your start>all programs list. If that doesn't work, scan for adware/spyware that may be running in the background.
Old May 8, 2011, 06:34 AM
"Quote This..."
If none of those work then just hide those updates. Win7 has had a few updates that don't want to install on certain computers. MS usually releases an updated update later.
Black belt in CAPS LOCK.
Old May 8, 2011, 06:48 AM
KRAFTIG's Avatar
This is what I see. I assume I need to remove " Microsoft.NET Framework 4 Client Profile"? Would this has any affects on other programs or such? Isn't Nero 9 dependant on this program?
Old May 12, 2011, 08:46 AM
"Quote This..."
I just received an automatic update that says it is supposed to resolve issues with updates not installing. KB2533552 for reference.
Old May 14, 2011, 07:07 AM
KRAFTIG's Avatar
I did not receive the update, checking now...
Old May 15, 2011, 12:58 AM
If you see the .NET frameworks, uninstall them, run your update. Make sure those two are unchecked before you install the updates. After you're updated, go back and install the .NET updates.
Old September 3, 2011, 02:38 PM
KRAFTIG's Avatar
Still have this issue, anyone figure it out? TIA
64 bit win 7 and 64 bit Office 2010 bonanza2000 O/S's, Drivers & General Software 8 October 6, 2010 08:49 PM
Anyone having problems with Win7 installing the latest updates KRAFTIG O/S's, Drivers & General Software 4 September 29, 2010 02:42 PM
Programs for Win 7 32 or 64 bit? GMJim O/S's, Drivers & General Software 0 January 22, 2010 05:28 PM
Any benefits of installing Windows 7 64 bit vs 32 bit? HoTiCE_ O/S's, Drivers & General Software 20 November 5, 2009 04:35 AM
Planning a new build? Need a x64 bit OS? I have a DVD copy of Win 7 to give away! Triggz New Builds 12 March 22, 2009 03:17 PM
